Question about Husqvarna Garden
How to reinstall drive belt on husquvarna yth 2242 lawn tractor ?
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
gisvc
  • 40 Answers
SOURCE: drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Posted on Mar 29, 2009
SOURCE: why does the deck belt keep breaking on Poulan
its possible the belt may not be on the correct pullies. check the diagram and make sure it is routed correctly.the guy i bought my used mower from had same problem. i corrected belt route and have not broke a belt in the two years i've had it
Posted on Apr 13, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
My drive belt broke on my 18 hp husquvarna 42 inch lawn tractor i need to put on a new belt
If you go to www.repairclinic.com, you may be able to view a video showing belt installation.
Aug 02, 2016 | Garden
Husquvarna yth 2148 riding mower trannsmission stops working after a few minutes and makes a noise,is there a way to add oil to tranny
There should be either a plug or air vent on top of the rear axle. It's not always easy to access this. Try looking under seat for easy access.
Oct 08, 2015 | Garden
Had work done last winter because drive belt kept coming off...Found the two bolts that hold transaxle in place kept falling out, also the plates that bolt over axles were worn/broken...have items rep
I own this model, I have not experienced this issue,something is causing excessive vibration to cause this issue ....a bad belt,misalignment or a sheave that is bent !
Sep 23, 2014 | Husqvarna Lawn Tractor  25 HP 54in Deck...
Need belt diagram on husqvarna lgt2654
Here is your manual. Please see Figure 5 on Page 7 for the deck belt routing. Other useful diagrams and pictures are in this manual as well.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602065.pdf
May 02, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Belt replacement on a husqvarna yth 2348 mower
do you need to know the belt configuration for this mower ive attached a user manual that shows the configuration and all adjustments on the deck and belt...
http://72.3.225.179/manuals/YTH2348-ow-e-96045000502-420798_r0.pdf
Hope this helps
Kind Regards
Brad
Dec 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do you change the deck belt of a 48in 21 hp husquvarna tractor
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532426477.pdf
Go to the above link and you can download a very good manual for it. It shows the routing of the belts as well as a lot of other useful information
Sep 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cant get a deck cutting belt for model YTH 2448T960430008 48 INCH CUT TRACTOR MOWER
which belt do you need the primary or secondary i have part # for ya i can also order them 180808 & primary part # is 174368 let me know if i can further help thanks wade
Jul 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
May 10, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
121 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
