Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My TV won't power up. If you try to turn it on, the green indicator light on the power button comes on, then sometimes you hear a squeal from one of the circuit boards inside and then the power indicator light goes off again, but the TV never comes on. I pulled the back off the TV but I don't see any discolored components or connections on the circuit boards...no obvious problem indications.
4 Suggested Answers
  • 608 Answers
SOURCE: TV won't turn on. Press the power button and the
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 15, 2010
Slinteriors
  • 8617 Answers
SOURCE: TV not turning on. When trying
Replace the deflection board. You can get deflection boards from www.tvrepairworld.com for your model.
Posted on May 24, 2011
Slinteriors
  • 8617 Answers
SOURCE: Model D52W19, Chassis ITC222. When plugging the
The deflection board needs replacement. You can get the deflections boards from www.tvrepairworld.com
Posted on Jun 25, 2011
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
CTR Television will not power up
What has happened is that the horizontal output transistor has shorted. The squeal you hear is the power supply running under a heavy load. The picture narrowing or being distorted indicate that the horizontal output was not operating clean. Something in the output section was not as it should be. Possible short in the output transformer/tripler unit or something loading down the secondary voltages generated by the horizontal output. You will need a tech to figure this out....If you are not a tech, then this ones a goner as far as fix it at home goes.....If you are a tech I might be able to talk you through the repair. Have someone remove the horizontal output transistor and I bet the squeal goes away.
Feb 10, 2008 | Televison & Video
Tv wil not turn on
The horizontal output transistor is most likely shorted, it's a 2sc5588 Rca Part # 259899 and there are a couple of subs available for that too.
The slight squealing you hear is the feedback voltage on the hot transformer as the B+ tries to increase and the s/d circuit cuts it off. Not an expensive repair...
Good Luck!
Bill
Feb 10, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
348 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
