Question about Goodman CLT48AER48 Air Conditioner
Compressor making buzzing sound wont start checked capacitor ok
  • 674 Answers
Check voltage at the load side of the contactor. Check continuity of the compressor windings. Disconnect the power first. Connect one lead of the ohmmeter to Common, then connect the other to the Run winding and read meter, then connect to the Start winding and read meter. Neither should indicate an open leg.
Posted on May 11, 2010
  • Brian Niten May 11, 2010
    Is the outside fan running? That would rule out the contactor. How did you check the capacitor?
HVAC fan is on, but the compressor attempts but will not start
Sounds like you have a condensing unit that has a lock up condition; commonly known as "Locked Rotor'.
A simple step would be to be sure the compressor is cool.
Start the unit, and as it try's to start, bump the compressor on the shell sideways to jar it , with a rubber mallet.
If the compressor starts... it may or may not start again at one point.
You can try adding a start assist, or commonly known as a Hard Start Kit. It's simple and the two wires go on the Run Capacitor In parallel with the wires with the compressor wires.
Usually the capacitor has a C common ..F fan.... and M motor terminals . The start assist wires piggyback on Common C and M motor. NOT THE FAN side of the run cap.
http://www.grainger.com/product/SUPCO-Hard-Start-Kit-4E240
Apr 30, 2014 | Heating & Cooling
Refrigerator makes a buzzing sound for 10 seconds clicks and stops making the sound. This happens every minute or so
I believe that buzzing sound is coming from the start relay and the click is the overload clicking because the compressor is trying to start but cannot because the start relay is defective, You may have a run or start capacitor bad also, Thanks Sea Breeze
Model Number?
Nov 17, 2012 | Refrigerators
The compressor light is on because the unit is cooling. It it not blowing cool "ac" air. How long is this process going to take? Do I keep the ac on or do I shut it off? It is also making a...
It sounds like the compressor isnt starting just because the lights on doesnt mean it is actually on.
If it is the compressor thats making the buzz heres what to look for when you start to hear the buzz does the fan slow down and then speed up after the buzzing stops? If it does your compressor is locked up you can try to replace the capacitor on the unit. If that dont work I wouldnt spend the money to replace the compressor too much money.
Jul 14, 2011 | Amcor AL10000E Air Conditioner
Refrigerator not getting cold on start up hear a buzzing sound,sounds like compressor.how do i check start capacitor.
Defrost refrigerator unplug at night leave door open plug back the following day. Also clean the dirt from underneath and the back of fan on refrigerator it might help
Apr 20, 2011 | Refrigerators
I have a Ruud condenser on which I just replaced the capacitor and contactor. When I power up, the fan motor spins very slowly and a buzzing occurs about every 15 seconds. The buzzing sounds like it's...
Hello Zing77,
I understand that you are having a problem with your Rudd condensor. The fan is turning slowly and the compressor is making a buzzing noise which has a Diversitech hard start conected to the capcitor.
You have already replaced the run capcitory on the unit and have attached the compressor wire to therm and c and the fan to therm and fan. The hard start kit shoudl be attached to the therm and c with your compressor wires attached to the same place. The hard start kit is to give the compressor the extra push (electrical charge) to start.
You need to check your connections and make sure that you purchased the proper run capcitor. If you have purchased the proper compacitor and the connections are right then you have a bad fan and the compressor as gone out on the unit.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | Heating & Cooling
The freezer is defrosting and the refrigerator is warming. the compressor is kicking on approximately every three minutes and is making a loud buzzing sound when it kicks on. is my compressor shot?
Probably not. The compressors are very sturdy and long lasting. The compressor is controlled by a start relay, and is protected by a thermal overload. It sounds like your start relay is bad, which would explain the buzzing sound. It takes a certain amount of time to cool down, and then tries to start again. The start capacitor and start relay should be replaced.
Nov 21, 2010 | Maytag 15 Cu. Ft. Top Mount Refrigerator
Frigidaire FRS26R4AW5 buzzing sound not cooling
Something has stopped your compressor. The part could be the start relay, start capacitor, overload or the defrost control board. where are the buzzing sounds coming from ? Sea Breeze
Dec 20, 2009 | Frigidaire FRS26R4A Side by Side...
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Goodman Condenser - Heat - Buzzing Noise every 60 seconds
It could be your compressor trying to start but not being able to do so. It shouldnt happen that often but in cold temp the overload protector may cycle that quickly. I reccomemnd to have it checked to salvage the expensive compressor.
Dec 24, 2007 | Goodman CLQ36AR49 Air Conditioner
Buzzing sound
the buzzing sound is the compressor trying to start. Unfortunately, it is locked up and the overload is cutting it out. It resets every couple of minutes or so. The problem is the compressor. You can try a hard start capacitor to see if it breaks loose, this is the cheap fix, otherwise it needs a new compressor, the expensive one.
Dec 05, 2007 | Amana ATB1935HR Top Freezer Refrigerator
Goodman CLT48AER48 Air Conditioner Logo
220 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
