Question about Cuisinart CBK-200 Bread Maker
The screw that holds the bread paddle came out! :(
The screw that holds the bread paddle came out so now, i can't make bread anymore because the liquid comes out of the hole from the bottom since the screw is now lose. what should i do?
  • 433 Answers
The sealed bearing in the base of the bread pan has probably failed. You will probably need a new bread pan. Hank
Posted on May 12, 2010
Sunbeam repair manual
Hi...Before trying to take it apart, you should verify that the paddle in the bread pan is moving or not. Take the pan out of the machine and try to turn the paddle by hand. It should turn free and smooth with little effort. If you can't turn it by hand then the bearing is frozen and the bread pan needs to be replaced. (no fix for it).
If the paddle moves freely, then the belt in the bottom of the unit is loose or broken. Reply to this thread and we'll help you out!
Hank
Jul 26, 2014 | Sunbeam Kitchen Appliances - Others
Can't remove kneading blade
If you baked bread in it and cannot get the paddle free, put enough water in the pan to cover the paddle and let it set for 5 or 10 min to soak the bread crust that formed between the shaft and the paddle. Then take a hold of the shaft on bottom of pan with hand or pliers to hold it still and try to work the paddle clockwise with other hand until it becomes unwedged from shaft. Sometimes it gets wedged on shaft pretty tight due to the beating against dough ball and cooked bread holds it tightly wedged.
Apr 06, 2014 | Sunbeam 5891 Bread Maker
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
The spindle that holds the paddle won't turn. It's stuck tight.
It may be hard to turn by hand but does it turn when the machine is
turned on? If so it is OK even if you can't turn it by hand
Nov 28, 2012 | Breadman TR555LC Bread Maker
On dough mode, machine won't knead
paddles could be slipping. that was my issue. Here's the solution if so.
What happened in my case is that the nut holding the rotor that drives the left paddle was loose, allowing the paddle to slip. Only one paddle would knead and mix. The belts in my machine are fine, in fact so massive I can't imagine them breaking. But access? Yikes.
So, forget the screws on the bottom. They just hold on the feet. Remove all the screws around the top of the baking chamber, the two that hold the control panel on, and the remaining screws under it. There are about 12 screws. Remove the 6 at the bottom of the baking chamber, but not the 2 that hold down the element. Remove the metal sides of the baking chamber (it's one piece). All this is to get access to the screws that really hold the works to the base. They're around the perimeter of the metal chassis on which the motor and element are mounted. Remove them (get help or arrange something to keep the control panel from exerting too much pull on the wires to the element. You could unplug the control unit but I didn't need to.)
Once you lift the motor assembly exposing the belts underneath, you'll see what's loose. Each nut holds down a metal plate beneath the rotor. If it gets loose, the rotor can move more or less freely and won't turn. It looks like they applied an inadequate dab of glue to hold those in place. I should have put in a star washer to keep the nut from loosening again. Next time.
Good luck getting all the screws back in the right places ;-) Machine works fine now.
May 27, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
Rt dough hook keeps sticking
Hi, Could be three things. 1) the paddle is sticking, or 2} the belt is loose or 3) the pan is not properly inserted in the machine. Take the pan out of the machine and see if you can turn the paddle freely by hand. If no...then lubricated bearing the paddle rotates on is failing. If everything is ok in the pan then the belt may be loose. Belts. pulleys and motor are located in the base3 of the machine. Remember to unplug machine before working on it. the third is self explanatory, but check with the manual to make sure. Good luck..Hank
May 24, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
One blade does not turn
The left blade on a BD 2300 bread maker did not turn when neading the dough. I took it apart by removing the six screws in the bottom of the case and the screws inside around the bottom outer edges of the metal insert. I then removed the screws holding the motor assembly to the base. I found that the metal plate attached to the paddle shaft driven by the gear had torn through the plastic gear, and was no longer driving the paddle. I made a new plate with the end bent down 90 degrees so that it fitted into a slot in the plastic gear. This is much stronger and the breadmaker now works fine. This is a weakness in the design and the failure could occur on either paddle. failures of the left paddle could be due to the toothed belt breaking, this drives from the right paddle gear. There is also a belt between the motor and the left paddle gear.
Dec 14, 2009 | Black & Decker B2300 Bread Machine
I love my bread machine, model 5890, but with every loaf of bread the kneading blade stays inside the bread. The bread is also difficult to take out of the pan. This has led to scratches in the pan as...
I usually take the paddle out of the machine at the end of the kneading cycle and before the rise cycle. (Do this with the pan out of the machine..just in case). You don't want to use anything in the pan that will scratch it. Usually a few quick taps of the bread pan on the cutting board will free the bread.
Dec 05, 2009 | Sunbeam 5890 ExpressBake Bread Maker
Bread pan stuck in Welbilt bread maker.
Welbilt Bread Maker Dough Paddles #BM-0550-12 wlbm055012.jpg Product ID: WLBM055012
Category: Bread Maker Parts-Bread Maker Paddles
Description: THIS PADDLE IS DISCONTINUED. ORDERS FOR THIS PADDLE WILL RECEIVE PADDLE BM-0550-01 AS A SUBSTITUTE - FIT AND FUNCTION APPROPRIATE FOR THESE MODELS. Welbilt bread maker dough paddle. Fits Welbilt bread maker models ABM100 ABM100-1 ABM100-2 ABM100-3 ABM100-4 ABM150R and DAK models FAB100-3 FAB100-4 FAB2000 FAB2000IV FAB3000
Jun 22, 2009 | Welbilt ABM3500 Bread Maker
Excessive wear between paddle and panshaft?
You can drill and tap the paddle, where it faces the flat on the shaft, and install a small setscrew. Something like a 10-32. Make sure you use a nylok screw or use a thread locking compound (available @ auto parts stores) to prevent the screw from working loose and getting into your bread! Just tighten the screw enough for a snug fit so that it can be removed for cleaning.
Jan 13, 2009 | Breadman TR2200C Ultimate Bread Maker
Cuisinart CBK-200 Bread Maker Logo
113 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
