Question about Canon PIXMA MP150 All-In-One InkJet Printer
Is there a paper thickness lever on my Cannon mp470?
Where is the paper thickness lever on my Cannon Pixima mp470? I can't find it at all!
The Machine
  • 788 Answers
SOURCE: Paper thickness lever postion
Is there a lever inside the printer that can be moved back and forth? If so set it about half way and try again.
Posted on Jan 17, 2008
SOURCE: Printer won't print
The lever is right above the ink cartridges. Turn on your printer and open the lid like you would to change the ink. You'll see a small blue lever that has two positions, left for regular paper and right for envelopes.
Posted on Mar 24, 2008
  • 183 Answers
SOURCE: cannon printer pixma mp470 paper
hmm, could you be more specific?. But I'll try to solve anyway
Paper jam error occurs because:
  • Paper end not detected by paper sensor; set paper properly and press Stop/Reset button
  • Paper sensor broken; replace paper sensor
  • Drive assy broken; replace drive assy
But before it all please check if any broken paper or another material is in paper path blocking the paper to reach paper sensor.
Posted on Nov 09, 2008
envision507
  • 30 Answers
SOURCE: recurent paper jam on Cannon Pixma MX300
Some printers have a certain paper height or paper load you can have loaded at one time. I would try loading a smaller amount of paper and see if that helps. If it still does the same thing your paper thickness lever may be damaged.
Posted on Sep 07, 2009
pineworks
  • 4041 Answers
SOURCE: hOW DO i FIND THE PAPER THICKNESS LEVER SO CANON S330 WILL NOT JAM?
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 26, 2010
My Cannon MP470 scans images/files on the computer slightly crooked although the paper is lined up perfectly. (I know how to use a scanner) Is there a fix to this?
I've had the ssame issue in the past and it is very frustrating especially if they are importatant documents. I put my papers side ways at times just to line it up. You can attempt to fix it rebooting it. Unplug it from every plug then restart it.
Sep 27, 2014 | Office Equipment & Supplies
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
Please tell me how to enable duplex printing in my Cannon MP470. This option is checked on the printing dialog box, but only one side of paper is being printed. Thanks in advance for your help! SMK
The printing dialogue box may allow you to select duplex printing but you may have to physically turn the paper over yourself UNLESS you purchased a DUPLEXER for your printer.
If the paper feeds from the back and the finished product comes out the front, you will have feed the paper back into the back of the printer.
Apr 03, 2011 | Canon PIXMA MP470 All-in-One Printer
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
Recurent paper jam on Cannon Pixma MX300
Sep 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannon printer pixma mp470 paper jam
Nov 09, 2008 | Office Equipment & Supplies
Canon PIXMA MP150 All-In-One InkJet Printer Logo
110 people viewed this question
old marine
old marine
