Question about Polaris 380 In Ground Pool Cleaner
Everything seems to be working w/ my Polaris 380 except it just sits on the bottom. I took it apart and flushed the hoses but they were clean. I notice a amall leak in the hose where it connects but doesn't seem like it would stop that kind of pressure. Could there be a clogged filter?
  • 198 Answers
The smallest amount of air getting into the lines can cause enough of a pressure drop to cause that
Posted on May 11, 2010
Change belts on polaris 380
open case then remove vertical tube then then remove paddle wheel assy then you have to remove wheel screws to change belts take pictures as you take it apart
Jul 29, 2012 | Polaris 380 In Ground Pool Cleaner
My polaris 380 does not move in the water at all. all lines are claer, I took the unit apart to check the belts both belts are on the axles, the large belt seems to be loose looking to me.should the belts...
The belts need to be "snug" but not over tight. If your debris screen is clean and you are getting good flow through the cleaner with water, but it is still not moving, this is a drive issue. It appears you are confident in understanding the mechanics of your pool cleaner, this should not be a difficult task. Lets first troubleshoot the cleaner:
  1. With the Polaris turned off, spin each of the wheels. All wheels should turn together. If not, replace the Drive Belt.
  2. Check the filter screen in the Quick Disconnect and clean if necessary.
  3. Clean the skimmer basket, pump basket, and pool filter.
  4. Check the hoses, connections, and swivels for leaks that could cause loss of water pressure.
  5. Check the wheel RPM.
Lets Replace the Belts: (You'll need a screwdriver and replacement belts before you get started) OR you can take your cleaner into a local pool supply store and have them install the belts for you!
  1. Remove the bag from the pool pump. Disconnect the collar of the bag from the feed house on the pump. Push in on the metal prongs to release the bag.Find and remove the four screws that are used to secure the frame to the base of the unit with a screwdriver.Lift up on the frame while pulling back at a 45-degree angle. Lift the frame off the base and set it aside.Push on the front belt while turning the wheel to disengage the belt from the pulley. Repeat this process for the rear belt. Take the belts out and set them aside.Place the new belts over the axle block shafts.Push the front belt onto the pulley while turning the wheel to put the front belt back on the pump. Repeat this step for the rear belt.Set the frame back in place on the base of the pump. Secure the frame by tightening the screws with the screwdriver.Attach the bag onto the pool pump and connect it to the collar to complete the project.
Dec 06, 2010 | Polaris 380 In Ground Pool Cleaner
I have suction but the head wont rotate it just sits there in the pool doing nothing
Inside the housing there are 2 hoses that sometimes come loose. Take the housing apart 3-4 screws and it seperated in half and you can see the hoses the clip could have come off. Simply reattach. These hoses are instrumental in the propulsion of the unit. Other things to check are make sure the screen at the wall connection is clean. If you have a Booster Pump make sure the pressure at the wall is significant. Also the Propulsion knob at the rear of the unit just above the sweep hose is set at 11:00 Position.
The Pool Tech
Jul 10, 2010 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
Polaris 380 stays in the deep end only. What's wrong.
Make sure that you have enough hose to reach the entire pool. This sounds simple, but this is a common problem with these pool cleaners. Make sure all three thrust jets of water are working on the bottom of the pool, also.
May 24, 2010 | Polaris 380 In Ground Pool Cleaner
Need picture of hose set up for polaris 380. Not just the diagram but an actual picture of it assembled. Thanks
should be a return outlet half way in pool closest to pump install fitting into wall connect Polaris and turn on filter pump and booster pump should move around pool adjust screw on back bottom for tail
Apr 29, 2010 | Polaris 380: Polaris Booster Pump
Which pressure should i use on uwf polaris assembly 380
It might not be your booster pump. First, check the filter screen and clean if necessary. Often, this is the only problem when these pool cleaners are having problems. Clean the skimmer, pump, and filter also. You will also want to check all connections and hoses to make sure that you don't have a leak.
Mar 14, 2010 | Polaris 380: Polaris Booster Pump
My polaris' wheels won't turn.
There are several things that could cause this. If everything else works exactly as it should then it may mean there is enough water pressure. Check to see if you can turn the wheels by hand. You should be able to turn one of them and the rest should turn also. If something is stuck between a wheen and the case it chould prevent turning. A couple of other things could cause this problem. If the jet from the water supply is plugged or disconnected it won't be able to turn the turbine that drives the wheels. If there is a problem in the gears, belts or bearings, shafts, adjustments, the turbine can't deliver the power to the wheels. When this happens I usually inspect the cleaner externally and then open it up with a screw driver and if the drive train works I take the cover off the turbine to inspect it. If you know where the screws are and how the parts come apart it should only take 5 minutes to get apart and a little more to put together. I usually put it back together until I have purchased the defective parts so I don't loose anything. Good luck.
Aug 19, 2009 | Polaris 380 In Ground Pool Cleaner
Drain pump
My husband did remove ours,and we too have a frigidaire 18" built in dishwasher. But ours won't drain, he says it might
be the pump, but he is hoping not.. everything works except when its draining. water just sits there in the bottom.. He took it apart and cleaned everything, but still the same issue.. Any suggestions for me will help also.. TY< PAMMIE
Dec 17, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Polaris 380 In Ground Pool Cleaner Logo
230 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
