Question about Brother LS-2125 Mechanical Sewing Machine
Jammed machine machine is jammed ,needle is not moving up and down but motor is running ?
  • 36 Answers
Check for thread jammed in the bobbin shuttle.
Posted on Jun 03, 2010
SINGER CG-550 C MOTOR HUMBING NOT MOVING NEEDLE
Motor is jammed due to bad drive. Locate the source of the jam and the motor will run.
Aug 18, 2017 | Singer Sewing Machines
Needle does not move up and down manually or when peddle is engaged. You hear motor run, but needle doesn't react.
sounds if you have cotton or fabric jammed around shuttle Hook casing or you have knocked the hook timing so far out that the needle is jamming against the hook assembly case. it sounds as if the machine needs to go in to have a complete check out. Have a look at some other answers I have given on sewing machines and how to retime them if you wish to give it a try to save yourself money and time.
good luck
Mar 16, 2015 | Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
My pfaff 1222e isn't working the motor runs but the needle doesn't move ~ the knob at the end of the machine won't turn at all
Check for thread jams... hopefully that's the problem and not a bent shaft in the thing.
Nov 28, 2012 | Sewing Machines
Consew Zig Zag CN2053R-1 needle bar is jammed
sometimes when a machine jams, the machine jumps time
taking it to a sewing machine shop to be serviced would be a good idea
Apr 30, 2012 | Sewing Machines
This is the first time I am using this machine... it worked for a little while (15 minutes)and then the needle jammed. The whole part that moves the needle up and down doesn't move, manually or by pedal. I...
Unscrew the needle and you should be able to move the balance wheel, take the needle out and then look for thread jammed in the bobbin case area.
Mar 03, 2010 | Bernina Virtuosa 150
Engine occasionally jams, still able to operate manually
It's been a while since this machines been oiled. try oiling both motor hole and needle operation.
Jan 24, 2009 | Singer Inspiration 4206
Brother LS-2125 Mechanical Sewing Machine Logo
80 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
