Most times upon powering on the TV I will get sound, but no picture. If you turn it off, and back on, most times you will get both.
  • bearcat77777 May 11, 2010
    This is a DYNEX flatscreen. Model DX-LCD37. I have repair tools, and have fixed many things, although more line voltage items than electronics though. I would like to fix this myself. Look forward to hearing from you.
    I checked the backlight, and it apears that is the problem with the no picture.(I see images with a flashlight shined at an angle to TV). But why would you think that the backlight or power supply is bad, since this is an intermitent problem? Do you have some more particular advice of what to look for in the set? areas to look, or inspect?
    Thanks
  • 10,515 Answers
Kindly Tell me the Make and Model of the TV?
This is an Internal Fault. Would you Like to Repair it yourself?
If Yes, do you have Tools like Multimeter, Screw Driver, Soldering Iron and other Electrical Equipments.
By Turning it OFF, you are resetting the TV that would Temporary Resolve the problem.
Let me know,if you want to Fix this Yourself.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 10, 2010
  • 1 more comment
  • taran_2005
    taran_2005 May 11, 2010
    Thanks for your response!!
    First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your backlight is not working. You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00.
    Let me know,once done.
    Hope i helped you.
  • taran_2005
    I have seen this Problem many times with Different sets, though i never worked on this. However, most of the Flat Panel TV worked on the same Principle's. Even though it is Intermittent, a Bad Inverter or Bad Caps / Faulty Caps on Power Supply Board or Faulty Circuitry might Cause the same.Bad Inverter could Cause Flashing On and Off as well as Intermittent issue's. The reason that it worked for few seconds / minutes / hours is that by Turning it OFF, you are actually Resetting the TV.
    The main Problem is that Flashlight Test is the ONLY way to Diagnose probability of Inverter Board being bad. For Further Diagnosis, you need to have Special Test Equipments.
    At this time, i would say, You shine the flashlight directly into the darkscreen - in a dim or darkened room. If you see faint images of the picture with the flashlight shining in the screen, then the inverter has failed.
    Let em know,if needed further assistance.
    Hope i helped you.
  • taran_2005
    Do let me know the Update.
    Thanks!!
Vizio tv repair?
Sounds like power supply board is bad
Jul 27, 2016 | Vizio Televison & Video
TV no sound, picture bleached and skewed
model. serial numbers would be helpful.
Apr 19, 2014 | Televison & Video
TV Flashing from Channel to Channel Non-Stop. Problem with the RCA F32689 32" TV My TV started jumping from channel to channel non-stop. There's no picture or sound - only channel numbers changing...
If still under guarantee take it back.
If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
Sep 21, 2011 | RCA F32689 32" TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
MITSUBISHI CRT TV MODEL CT-33AC2SL
check for dry joints in power supply
Oct 09, 2007 | Televison & Video
Picture blanks out
Check your powercord. Unplug it overnight, then plug the power cord back in the morning. If that doesnt help, it means that something is going on with your set. Sometimes your power cord has shorted out and needs to be replaced. Generally you can find them under $100 depending upon your set...
Aug 21, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
