My canon printer keeps saying inner cover open canon mp530
    President:
  • 1,335 Answers
There is a small access door that is flipped down when you access the print cartridges. More than likely, this small plastic door is down and just needs to be flipped up. Raise the clamshell printer cover and check this door.
Please rate this solution. Thanks.
Posted on May 10, 2010
    Scholar:
  • 166 Answers
Please do the following steps as mentioned below:
  1. Switch the printer OFF
  2. Press buttons 1 + 2 + 3 and 4 (simultaneously using four fingers)
  3. Keep pressing this four buttons for 10 seconds
  4. Release the On/Off button (number 4) (Keeping pressing the others)
  5. After a few seconds (when the printer go ON) you can release buttons 1, 2, 3
see if it works out for you .....
Inner Cover is Open on printer screen. It is not open??
check the sensor that is the Inner Cover, you may have fallen out of place it is
Mar 10, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Where is the serial number on a Canon PIXMA MP530 multifunction printer?
The serial number of the PIXMA MP530 is located inside the printer, as shown below.
  1. Lift the Scanning Unit (Printer Cover) until it locks into place.
  2. When the printer is powered on and the Scanning Unit is lifted, the Paper Output Tray will open automatically. If the Paper Output Tray does not open after several seconds, press the Open button to open the tray manually.
  3. Open the Inner Cover.
    The serial number is attached to the back wall inside the printer.
    It starts with four letters (AAGA) and ends with five numbers. Example: AAGA01234
Mar 04, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Feb 19, 2011 | Canon PIXMA® MP530 All-In-One Printer
What does it mean when the alarm window says "inner cover is open"?
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
Nov 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a Cannon Pixma MP530, when trying to print I get a message saying "Inner Cover is Open". I cannot find out what this means. Can you help please
moz-screenshot.pngIf you look where the paper comes out of the printer you may find the cd tray is down (a small plate lying horizontally) flick this up to vertical until it clicks in place. Hopefully this is your problem
Nov 11, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 error code - "Check Printer 6500"
Hey welcome to fixya. Hope u 'll be fine
  • Properly seated
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Apr 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My printer won't print because it says the inner cover is open. How do I close it.
The inner cover is the flap that you drop down to replace inks, there's a small switch on the right inside that goes bad, you can try opening and closing a few times, but you may need a shop to replace the switch.
Dec 08, 2009 | Canon PIXMA MP530 All-In-One InkJet...
If I want to print it doesnt work, info comes "inner cover is open" what can I do?
Hi Sir, This Inner Cover is actually the plastic door which is usually opened to install or remove the ink cartridges. This door or cover must be open or not properly inserted. Try Re-inserting it and set it Firmly.
Thank you Sir, Have a nice day.
Sep 25, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Getting the inner cover is open message when it is closed
i think you could not adjust printer cover properly.so we get many time this type of message in practs. becuse printer sencer are attached in cover and paper fedder and another parts. while they are not connec between them . they bring that type message.....thanks
Jun 16, 2009 | Canon PIXMA MP530 All-In-One InkJet...
335 people viewed this question
k24674
jasbo
jasbo
