Question about Microsoft Xbox 360 Console
Turn xbox 360 on and no picture on tv, xbox lights up green but doesnt send video output. tv is hd and i have tryed hooking the xbox up to another tv, tryed using hd and regular video outputs, tryed new video output cord, nothing seems to work i think its an internal problem on the xbox
  • 22 Answers
You may need to change your HD settings on the back of the console ( HD setting is actually on cord ) I had that issue when I first went online w/360 . If that does not help u know X box costumer support will repair any damaged system prob. no cost and does'nt take as long as they say.
Posted on May 10, 2010
Ring of light has 4 quadrants flashing green - no picture on TV
Red Lights are a problem for Xbox 360, however green light problems are hard to find, still you can try following steps to check where the problem lies
1) Boot with no HDD and see if that helps.
2) Also remove all your inputs in the back, and reinsert them. Make sure your HDMI/VGA/Compenent input is plugged in correctly.
3) Try switching the output from HD to SD, if you have a HD VGA Cable for your Xbox 360
4) Turn the Xbox 360 off, turn it on with the controller, as it turns on hold the Y button and the Right Trigger, this will put all audio/video settings to default.
If the above given steps do not help, kindly call Microsoft Support and try to get an answer from them to this issue, and if required you may have to send your console for repairs.
Dec 07, 2009 | Microsoft Xbox 360 Console
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
No picture from my xbox 360 to my tv??
It is the solder under the GPU chip. Same as the 3 red light problem. YOu can send it to us if you want it fixed.
xbox360fixer@verizon.net
Thanks
Jan 03, 2009 | Microsoft Xbox 360 Console
Have sound no picture and 2 green rings around power button
They are green?!? usualy when people have problems with  the xbox 360 hardware, the lights turn red. This xbox 360 may have a birth defect... Best thing to do is call 1800-4my-xbox. Talk to a representative about sending your xbox in, ONLY if you have not voided the warranty. If so, you will most likely have to buy a new xbox or new motherboard for it.
Also try changing your video settings to tv instead of hd, or hd if it is plugged into a hd tv. You might have toggled the HD switch on the video/audio chords.
Dec 31, 2008 | Microsoft Xbox 360 Console
360 help
This is a picture of the HD AV cable:
http://secure.llamma.com/catalog/images/xbox_360_hd_cable_component.jpg
On the back of the part which connects to the 360, there's an optical output.
If you then get one of these leads:
http://www.thericheygroupllc.com/images/optical%20cable%20toslink.jpg
It should send the 5.1 digital audio from your Xbox to your HD. I'm sure your TV should have an optical input on it somewhere!
Jul 18, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
No picture
My xbox 360 elite video port went out on my previous xbox, and on the one i just got. it could be your video port on your xbox or it could be the your tv. Hdmi cords usually dont go out so i dont think it could be that. A way to check if its you xbox would be to try the regular cords that you get with your xbox on the same tv and see if it works. If it doesnt, try the same thing on a different tv. if it doesnt work on that tv either then its your xbox. if it does work, then it must be the other tv.
May 05, 2008 | Video Game Consoles & Games
No video output, audio output fine
Did this console work fine before, or did you just set it up and it has no video? If the console worked fine before but now it doesn't, you are likely right about the cable NOT being the true cause. However, if you've never seen a picture from your XBox360 then perhaps the cable IS the problem. You mention "all 3 video lines", leading me to believe you are using the HD A/V cable with blue, green, and red connections for video. In order to use this cable, you MUST have an HD capable TV (480p, 720p, 1080i, or 1080p). Try switching the A/V cable switch from HD to TV and using the yellow video plug.
Apr 13, 2008 | Microsoft Xbox 360 Console
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dec 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
276 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
