Question about Whirlpool Washing Machines
Whirlpool WFS1071BW front load washing machine -
Clean pump light is on. Have cleaned filter and turned machine back on. will not drain/spin. Can't open door to get clothes out.
Unplug your washing machine and then you will be able to get the door open and the clothes out. You may need to leave it off for awhile to get it to work but make sure you have a bucket ready to catch the water coming out.
Posted on Oct 19, 2010
My front load whirlpool washing machine got to spin cylce and stopped. The door wouldn't unlock and the light showed add garments but it hadn't finished spinning the others any suggestions?
Your drain pump filter probably needs cleaned. YouTube has several videos you can watch on how to do it. It's an easy fix. Type " whirlpool duet drain pump " into the search bar. Let me know if you have trouble.
Jan 12, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The red light 'Clean Pump' on my WFS1071BW washing machine is on. How can I access and clean the pump? Thank you for your response.
the small cover trim across the bottom front of the washer comes off. under it is your pump clean out it is a cap you twist off to clean out the pump. have a towel ready water will come out. hope this helps and please rate me thank you...
Jun 06, 2011 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Duet Sport--won't completely spin out, leaves water in the tub. I cleaned out the drain filter, it kind of works for 1 load then goes back to not spinning out completely.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool front loader washer has "clean pump" light displayed. How do i clean the pump.
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 22, 2010 | Whirlpool AWOE8748 Front Load Washer
Duet GHW9150P Front Load Washer: front load whirlpool washing machine runs fine unt...
You can try this:
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
614 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
