Question about Sony Cyber-shot DSC-N1 Digital Camera
My Sony Cyber-shot DSC-N1 cameras flash quit working. I have reset (initialized) it and the flash still will not work. I can use all other functions as long as I set it of "no-flash"
  • 1 more comment
  • Kelly Adame May 10, 2010
    I never had any error codes show up. It just quit working. I had it repaired through Sony about a year and a half ago, it had been dropped while the lens was out, and it wouldn't go back in. They fixed it when I sent it in, but it was a very expensive flat rate charge. I may just have to invest in a new camera. This one is 4 years old but I love it.
  • Kelly Adame May 11, 2010
    It doesn't appear to be cracked. I will have to try to find a repair service other than Sony to see if they can take a look at it. Sony wants to charge a flat rate charge and I think it is too much,
    Thanks for the information. Appreciate it.
  • 10,594 Answers
If your Sony DSC-N1 shows blinking error like E:91:xx on its lcd screen when you try to use flash then it is flash circuit board ST-129 problem as that will be replaced to fix the issue.
Part number of ST129 board is as follows:
A1151928A... ST-129 FLEXIBLE BOARD, COMPLETE
It is qualified camera tech job to replace it because camera will take apart.
Hope this info will help you.
Let me know if you have additional question.
Thanks.
Posted on May 10, 2010
  • Shahid Electronics
    Shahid Electronics May 10, 2010
    Ok, if camera does not give any error code then most probably its flash bulb got broken, give close look to flash bulb on front of camera, a tube would be broken inside.
    If that is broken, need to replace it, it calls Flash Unit and part number is as follows:
    147960111... FLASH UNIT
    Thanks.
    Shahid Electronics May 11, 2010
    Yes, local camera repair shop will fix it in less amount.
Sony Cyber-shot DSC-N1 Digital Camera wont come on
hi
do you have a manual for that?
if i could only remember correctly, you have to press a button to go into safe mode for that. you are experiencing an internal error that requires a reset that can only be done in your cameras safe mode.
hope this helps.
Jan 21, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Sony cyber-shot DSC-W100
I had same problem and found out after leaving the battery out for an extended time (4 hours) it totally reset and worked. The initialize function on the camera did not work.
Dec 08, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Reset factory settings of sony cyber shot DCS-S650
Hello rkhanna,
Initialize function reset all data/ settings to factory defaults including date. I think, LCD Back Light of your cyber-shot is not working and its hardware problem. Contact nearest Sony repair shop.
May 22, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
E:91:01
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Problem with sony dsc-w30 cyber shot flash
I found this solution in Yahoo Answers. go into the Setup Menu and find "Initialize". Select Initialize to reset the camera adjustments. Then try using the camera again.
Feb 03, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-W50 issues
hi there
you can try doing this and it should work and solve the problem for you
  1. Press Menu button
  2. togle across from REC Mode to setup
  3. togle down three times from camera to setup 1
  4. togle across into sub menu
  5. togle down from four times to Initialize
  6. togle across again to the sub-menu
  7. togle up from cancel to OK
  8. press center button to accept the OK choice
  9. Screen changes and so press okay again
  10. It should restart the camera
  11. Opening on the 'Clock Set' screen
  12. togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
  13. If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
Oct 01, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
E:62:10
Hello, this error message means that there is an melfunction in angular velocity sensor, peripheral cicuits. Simply speaking steady shot function does not work well. Please contact nearest Sony Dealer. Best regards, Arpi
Jun 11, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Sony Cyber-shot DSC-N1 8.1 Megapixel
http://www.dcresource.com/reviews/sony/dsc_n1-review/ Hi there, just fixed mine. Had the same problem. Click on link above. Leisa1
Jan 20, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Sony Cyber-shot DSC-N1 Digital Camera Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
