Question about Tablets & eReaders
Gateway Tablet, BSOD unmountable_boot_volume
1. CMOS does properly detect drive.
2. XP boots far enough to ask for normal/safe mode
3. Windows logo appears for a minute, then:
4. Gets BSOD: [UNMOUNTABLE_BOOT_VOLUME], then
5. I Boot from XP CD, Recovery option "R" (or install)
6. Then I get that there are no hard drives installed
7. It can go looping like this endlessly.
  • 1 more comment
  • heavenishome Apr 03, 2008
    You cannot reformat and/or reload XP if the installation XP CD cannot even see the drive, as per point 6 in original posting.
  • Kyros2 Jul 17, 2008
    Gateway Tablet PC
    CX2610
    Intel Pentium M
    I have tried booting Windows XP Pro, and Windows XP Tablet edition, both times, the same thing happened. The setup began initializing and it gives the option of repairing, or reinstalling windows. When I hit enter to reinstall windows, it tells me that no hard disk was detected and that a possible manufacturer diagnostics/setup program might need to be run. It never gives a BSOD, but the setup will not recognize the hard disk drive. When I restart, I can enter windows normally, so the hard drive is obviously connected correctly. Any ideas on possible programs used to make this work? Thanks
  • willomeina Feb 25, 2009
    I have a toshiba tablet --
    Starts up -- but no harddrive detected --
    I have an i/o error 01 so I replaced the hd ribbon connector -
    Still no luck -
    I have tried to run fix-it cd's - no luck..
    I have installed a different hard drive also -
    Thinking that was the initial issue --
    (the harddrive was the exact same oem hd from toshiba pre-installed for my tablet)..
    All this started -- when my beagles were being jerks and knocked my tablet off the coffee table.. It work for about 2hrs after the incident -- but after that -- nothing..
You have to go to gateway and download the driver for the SATA controller then save it to floppy or cd then hit F6 durning install then it will ask you for the driver. This Tablet will not see a non-gateway cd if you have the one that came with the tablet then you are good, but if not you will need to do this for the current drive or if yo upgrade to newer drive. Hope this get you started, I had this same problem and I thought it was my motherboard was bad because it would not see the hard drive during installation. This fixed my issue with the drive not being seen during installation of the OS.
Posted on Nov 26, 2008
  • 111 Answers
You have to reformat & reload XP
Posted on Mar 29, 2008
SOURCE:
Hw to get safe mode off a Nextbook tablet
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Mar 25, 2018 | Nextbook Tablets & eReaders
How do you Stop Safe mode,on the tablet?
Stop Safe mode on the tablet Google Search
2. Tap "Power Off".
And lastly...
Mar 07, 2018 | Tablets & eReaders
My Kocaso Android Tablet 4GB it loads to the android logo n stays there is there a way to reset the tablet
Hi.
If you recently had a modification on your ROM, you may be experiencing a BOOT LOOP which is common to Android Tablets. A factory reset would be the best solution to that. Here's how to do it;
Turn-off your Tablet by long-pressing your power button. To be sure it's totally shutdown, wait for at least 30 seconds before proceeding to factory reset. If your tablet's battery can be removed, it would help if you detach the battery and put it back again before proceeding.
Resetting your Tablet to factory setting erases all the data in your tablet's memory, so you have to be ready to encode all contacts again and stuff like that.
Factory Reset Proper;
1. Press VOLUME UP and POWER button at the same time without releasing until the device boots to "Recovery Mode".
2. In Recovery Mode, scroll down by pressing VOLUME DOWN until you reach the option "Swipe Data/Factory Reset" or any equivalent to Factory Reset therein.
3. Follow through the succeeding menus until the device initiates the reset.
Note: If your Device has a HOME button (usually located at the Center-bottom of the LCD), the buttons to be pressed to enter into Recovery Mode are HOME and POWER at the same time. Release only after the device shows it boots in Recovery Mode.
I hope this helps you.
Apr 23, 2014 | Tablets & eReaders
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
How do I install my Win XP whn I have changed my harddisk ?
plz follow the steps...
1. Insert windows xp bootable cd into the drive
2. Power on the machine
3. When the logo displays, press F12 to show the boot menu
4. Select the CD/DVD
5. System will start the job
6. After showing Setup is starting windows, it'll shows the install option
7. Press ENTER
8. It'll show the drive but the drive is not partitioned
9. You can easily understand by reading the instructions
10. While creating it'll ask for drive space
11. Put 50000
12. Press ENTER
13. It'll ask for type of file system that you have needed, select the 1st one (Quick using NTFS)
14. It'll ask 4 format the specific drive. for that you have to press 'F'
15. It'll format and copy the needed files
16. System will restart. After restarting it'll start the job. plz wait.....!!! (system restart many times to complete its job)
17. While working it'll ask for the product key, time, etc.
18. Sit infront relax and give the needed information that you can understand easily
thanks & regards
Anas K A
May 28, 2011 | Fujitsu Lifebook T1010 Tablet PC
When booting, the system hangs at Windows XP logo. It does the same when booting (or trying to boot) into safe mode. What could be the problem and how do I resolve it? I tried to use the Windows XP CD to...
You can access the BIOS usually by pressing "esc", "F1", "F8", or "F12". One of those buttons
should work.
As for the hang up at the logo, it sounds like your hard drive might have crashed. The same thing
happened to me on my Vaio.
Feb 09, 2011 | Toshiba Portege M700-S7002 Tablet PC
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Will not start up after system recovery done with disks.
If you have a Windows XP or Windows Vista CD (or if you can borrow one), insert it into the CD Drive and restart the system. Boot from the CD, and choose the "R" for Repair console.
Log onto the Windows installation you want to repair.
At the prompt, type FIXMBR and answer yes.
Type exit.
Jun 12, 2008 | Gateway M275 Tablet PC
Toshiba laptop - Tablet with Windows XP
Greetings,
If we had a clarity on the OS you are using it would have been easy. Do not try to change the mode. Shut down the comp and then try to restart, as it starts then tap the F8 key on the keyboard. We'll get the option for Safe mode. If still you do not get through.
Not being sure why you want to goto safe mode you can always use a plug an play external CD ROM. In case the issue is not resolved for safe mode you'll need to repair the Windows.
Regards,
TechSup1
Mar 26, 2008 | Toshiba Portege M205-S810 Tablet PC
Tablets & eReaders Logo
620 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
