Question about Bruder Cat Skid Steer Loader
1998 751 Bobcat ! How do you remove fuel tank ?
1998 751 Bobcat ! The gas guage shows full but runs out of fuel. When adding ,you can only get 3 gals. in before it runs out. Its not picking up the other 10 gal. How do you remove the tank to check the pickup ?
  • 1 more comment
  • captain4uus
    captain4uus Jun 06, 2012
    i have same issue...how long is the line in the tank and is it rubber fuel line??? will try to replace it tomorrow
  • Anonymous Mar 12, 2014
    fuel gage stopped working
  • Anonymous Mar 14, 2014
    adjust steering on 751 bobcat
Hi i had the same problem . lift the cab up and look back by the hydrulic pump the tank is under it but you do not need to pull it out there is a 90 degree fitting for the supply line pry out the fitting and the tank strainer is hooked to it , if not it fell off in the tank .if it is there it is must likely cloged up it is a cheap part to replace . well i hope this helps you
Posted on Sep 26, 2010
Your pickup line has curoted in the tank. Go to dealer and get a new line for inside the tank. Just changed mine and it works like a charm. Just raise the cage and you will see the lines going into the tank.
Posted on Aug 06, 2010
Town and Country Van running out of gas and guage says half a tank what could be the problem?
If your fuel gauge is showing you in accurate readings this is normal to all vehicles that are not used to fill-up gas full regularly but sometimes the cause of the inacuracy is due to faulty float valve in the gas tank you need to replace it
May 09, 2014 | 2005 Chrysler Town & Country
Chevrolet Suburban 2500 8.1L runs out of gas with gauge reading 1/4 tank full. I refill tank with 25 gal ( fills tank) then it runs out of gas again after using 25 gal. secondary tank in rear doesn&
Get manual online under $10-15 and get complete guide on whether to repair or not, service it, and how to repair etc
you can get it from reliable-store or manualslife
really good plus instant help also availabel
Feb 12, 2018 | 2005 Chevrolet Suburban 2500
GAS GAGE WANT STOP READING EMPTY WHEN GAS IS IN IT
To confirm if the fault is with the Rheostat float within the fuel tank or the fuel guage in the dashbboard, you can remove the wiring to the fuel tank float. If the guage reading changes- to full- then the guage is good and the fault can be a jammed rheostat which can be removed from the tank and replaced after draining the tank. The guage can be tested on the outside with a ground wiring to the plate of the fittings and as the float is moved the guage must show a change in reading. if not the voltage must be measured to confirm the working of the guage.
Oct 19, 2011 | 2001 Buick Century
WHEN FUEL GUAGE REACHES HALF WAY THE NEEDLE WILL DROP TO EMPTY. TRY TO PUT GAS IN AND MAYBE GET 5 GAL IN AND THE NOZZLE CLICKS OFF. IT WILL SHOW 3/4 TANK THEN. I KNOW IT SHOULD TAKE MORE WITH THE MILES I...
from what you are describing you have two(2) different problems
1- the wacky gauge- its acting like a grounding issue- wires are crushed/smashed on tank connector
2- not filling - venting issue- vent line to top of tank pinched
3 solution- run tank down to 1/4 or less and DROP tank down to inspect wires and hoses- sounds like at some point in time the tank took a hit and wedged itself upwards against the underside,pinched the vent line so there is too much pressure in tank and also crushing the wires/plug causing the erratic readings(worse with less weight as the tank moves more)
if unsure of how to do this- you can get a manual such as a HAYES book at auto parts story- good luck
Jun 24, 2011 | 2004 Chrysler Pacifica
My fuel gauge isnt working, it sayed over Full untill i hit half a tank then showed on F then 1/2 a tank was actually Empty. what could be wrong?
The fuel sending unit has a rhetrostat its a variable resitor ..As fuel is added the fuel lever mover along the rhetrostat and gives resitor signal to the fuel guage, the fuel gauge interpets this as level indicators to show on the gas tank.
Apr 26, 2011 | 1989 Jeep Wrangler
I have 1990 Mazda Protege Se. Gas fuel guage is showing empty but about 2-3 gallons gas is in tank. When I fuel it up to full, gas guage showing full again. What's the problem? How to fix?
the extra fuel is "reserve" to get you to a fuel station... this is normal. If you were to run it completely out you will damage your fuel pump, fuel is used to cool the fuel pump. Soo... DON'T run it so low!
Feb 14, 2011 | 1990 Mazda Protege
Vehicle runs until gas guage is at half full, then dies, gas added will cause vehicle to run again
Remove the fuel tank an check the line connections at the pump, good time to check the fuel guage also
May 16, 2010 | 1996 Ford Explorer
Fuel guage shows 3/4 full right after fillup
It is most likely your fuel level sending unit has gone bad. It sits inside your fuel tank and uses a float similar to that uded in your toilet to tell the fuel guage how much gas you have in the tank.
In many cases, the unit can be accessed for replacment by removing the rear seat and opening the access port (3-4 screws) and removing the sending unit from the top of the fuel tank. It looks like this...
Feb 17, 2010 | 2005 Chrysler PT Cruiser
1987 fuel level guage issue 87 F150 Lariat XLT 5.0 2wd. Have a very similar situation. Front tank position shows empty even when I know there is gas. Rear tank position shows full after refilling but...
the gas is regulated from the switching valve you control off the dash. Check the valve to hear it switch
have a friend help you do this. it will be located under the truck between the two tanks. You may have a faultly valve or switch rattling inside changing the tanks setting also while driving which will be hard to tell
Jan 31, 2010 | 1987 Ford F 150
No fuel but yet there is
replace sending unit in tank
Jul 05, 2009 | 1996 Chevrolet Cavalier
Bruder Cat Skid Steer Loader Logo
3,081 people viewed this question
Top Bruder Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
Are you a Bruder Toy Expert? Answer questions, earn points and help others
