Question about Air Tools & Compressors
What is the CFM FOR THE DAYTON BLOWER MODEL 3C073A 2hp 575volts 1750 RPM 15 in dia.
3 Suggested Answers
mrhappyface
  • 205 Answers
SOURCE: motor will not start under load, but will start from empty tank.
bad check valve allowing air from tank back to the pump which when trying to restart has all that air pressure in pump cylinder pushing against the pump piston and with this load you will end up burning the motor
Posted on Feb 26, 2009
  • 174 Answers
SOURCE: what is the cfm rating on a dayton gas powered air compressor
I would try calling Grainger.ask for tech support on their compressor.you can also order parts for this if they are still available.
Posted on Oct 23, 2009
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
How am I getting oil in the hoses?
Hello Aaron, It sounds as though the piston rings in the compressor pump are not seated in the cylinder. Could they be worn out from use?
Jul 01, 2015 | Dayton Wire Wheels Dayton 2VKY3 Evacuation...
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
I got a dayton 2hp. electric motor model#2N982M it appears you can wire it for 110volts,220volts, or 440volts - need a wiring diagram mine partially worn off.
That motor is a three phase motor and will not run on 110 volts. It is also a high RPM motor with a lot of torque and MUST be mounted to a solid surface before it is powered up or it could rip your arm off as it flies across the room. If you have access to three phase power then you could power that motor but not with standard household electrical service.
Heres a link to some info for it
Jun 17, 2011 | Dayton Heating & Cooling
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Low rpm on blower motor
The 1350 RPM Speed is for 50HZ. The motor will only run at 1525 on 60 HZ.
Nov 30, 2009 | Dayton Shaded Pole Blower 480CFM. 2 Speed,...
Have an Chrysler Corporation central station air
Owner found the original set of design drawings. Added up the total cfm of the outlets, and modelled the duct system to find the design static pressure. At this stage of it's life, we're limiting the AHU to only 3/4 of design load.
Nov 14, 2009 | Heating & Cooling
I have a dayton kitchen exhaust blower mod no. 4hz65, 1/25 hp, 1550 rpm, 115 volts, 1.5 amps, 8 inches. it does not seem to do the job, do i need a stronger one?
Remember air will only move as fast as the size of the exhaust pipe in relationship to the fans ability to push. Make sure yours is the proper size for the fans volume.
Jul 07, 2009 | Dayton Exhaust Blower to vent your grow...
Air Tools & Compressors Logo
225 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
