Question about Canon PIXMA MP830 All-In-One InkJet Printer
A piece of foam sponge under the ink catridges has broken, and the printer will not cleanly draw paper for printing - it jams.
  • 241 Answers
The sponge under the print cartridges is to soak up the ink when cleaning the print heads. If part of it broken off and lodged in the rollers where the paper is drawn into the printer then try to locate the sponge and remove it. Sounds like it's lodged somewhere and jamming the paper feed.
Posted on May 10, 2010
Canon MP830 had a paper jam that forced a black sponge/foam piece out. Prints ok now. Do I need the sponge/foam piece?
Hi!
You must replace it because the sponge absorbe your waste ink from your cartridge. If you don't replace it, your cartridge will not long last.... thanks
Sep 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
HP842C continues to print with nothing on the paper but a line across the top of letters and numbers. The orange light will not go off. There was a paper jam which I removed then paper continued going...
Check your Catridges, they might be dried up if new, or empty, Remove them shake them to feel a presence of ink or tap them on a piece of paper to verify if ink will comeout if not then they are empty and need to be replaced they they have a bit of ink you need to shake and try printing again if this persists change the catridges, also make sure that the Printer is Clean, verify the Catridge Carrier for any dry ink deposits.
Dec 03, 2010 | HP DeskJet 842c InkJet Printer
Paper comes out torn and see loose piece of foam
OK
Remove the ink cartridges and print-head then remove the long skinny piece of foam and wash it and dry it - don't wring it out but press it between sheets of paper towel. You'll see lots of ink come out of it.
Using more paper towel, clean out all the ink you can find inside the printer - there will be lots. Look at the end where the print-head parks and you'll see 2 more sponge pieces. Don't remove them but use plenty of towel to absorb as much ink as you can from them.
Once you think everything is clean look for any loose bits of paper inside and remove them. Then, refit the now dry piece of foam. It's not as hard as it looks as the thing is shaped so that it will only fit in one way. Make sure it is properly seated then refit the print head and the carts and switch on.
I've had this happen twice in the last year on my ip5200 - particularly when using scrap paper.
Dec 31, 2009 | Canon PIXMA™ MP510 All-In-One InkJet...
Ink and paper jam red ligths on ana off ?
Epson Stylus Printer
Please remove catridges from the Printer.
Clean the place with a white cloth along with cleaning liquid in the seat, where the catridges are sitting.
Use genuine Catridges for this Epson printer.
Dust and other things to be removed from the Printer.
Insert the papers in the In tray and check for the paler pulling sensor is working properly.
Paper jam can be taken care, after carefully removing small pieces of papers jammed in the printer.
Finally switch off the printer and machine and reboot the system.
Still problem comes, please contact the local printer engineer to assist you in this issue.
Jul 19, 2009 | Epson Stylus C66 InkJet Photo Printer
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
MP830 has a 6A00 code
The 6A00 is a Canon generic code for paper path jam and seems to be a very common problem with these printers. Click Here to read some resolutions to this issue that may or may not work for you.
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ip4300 canon pixma
I have the Canon Pixma iP4000R printer. I had an error code of a600 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Nov 19, 2008 | Canon PIXMA iP4000R InkJet Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Had paper jam. removed paper, now getting 11 flashes, but cannot clear error as per manual instructions. getting service error 6A00.
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it(purge unit). The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
203 people viewed this question
old marine
old marine
