Question about Toshiba E-Studio 3511 Color Copier
Toshiba estudio 550 copier misfeed to finisher When I copy a document, the paper won't pass through to the finisher. Is there something I may have missed when I connected the finisher to the copier?
  • rashid majeed May 11, 2010
    Do u have fixed all the conectors ?
  • 59 Answers
Hi just cheq the pathe of finisher or path sensor of finisher
thanks
Posted on May 15, 2010
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
E-studio 550 says to close saddle stich. What is the saddle stich?
This is on your finisher it is a accessory that someone had to purchase with the copier. Saddle stitch is how you make books and the staples go a certain way, it is a fancy stapler device that has a door to remove jams an d such. on that access door is a hidden microswitch that tells the copier if its safe to run paper through there or not. If posted on Aug 7 you either found out by exploring, had a service call to correct it or disconnected a really expensive finisher from your copier..... ~~~~> SC
Aug 07, 2014 | Toshiba BR ESTUDIO 550 - 1-SD YLD BLACK...
Toshiba esstudio 500 misfeed to copier error what to do?
Sounds like a paper is jammed in the copier. Pull out the tray and make sure all paper is removed the reinsert the tray.
Jul 30, 2012 | Toshiba E-STUDIO 550 Copier
How do i print front and back of paper?
If the your copier machine don`t have the duplex unit for make 2 sided copy to use for 1 sided the paper tray and to 2 side the by pass(manual)paper tray.
Oct 04, 2009 | Toshiba Estudio 200L Copier
Automatic document feeder
U need to check whether the flap-exit is working or not.
http://img.photobucket.com/albums/v390/anthonydidi/flap_exit.jpg
May 12, 2009 | Toshiba Estudio 200L Copier
Misfeed in finisher
finisher is the unit attached to the copier on the left.
open door and look for any green handle, these are what you need to move to locate the jams
Oct 19, 2008 | Toshiba E-Studio 3511 Color Copier
Misfeed in finisher
just check propely any small piece of paper is in machine or any sensor in paper path is disturbed check all sensors and there levers .or take a hard file cover and from bypass with ur hand pull it in copier and send him to toward exit tray .just off copier first and do this .
Oct 19, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba E-Studio 3511 Color Copier Logo
480 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
