Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Leaking water on floor.
We have water leaking on the floor under the freezer side, and a layer of ice is building up under the bottom sliding drawer in the freezer.
    President:
  • 949 Answers
This is typically caused by the defrost drain. I have put together some instructions on how to resolve this, follow the link below and let me know if it helps.
http://www.fixya.com/support/r4686046-water_leak_from_freezer_ice_freezer
Posted on May 11, 2010
Whirlpool dripping water from freezer drawer
See inside freezer box floor. Do you see Ice layer build up. If so then your defrost drain line is clogged.
Sep 23, 2014 | Whirlpool Refrigerators
Ice build-up on the bottom of the freezer drawer
Water on the freezer floor has only two sources, 1) ice maker overflow/leak, or 2) defrost drain plugged. For the first you can turn off the ice maker and shut off the supply water for a few days to see if the problem recurs. If this is the problem determine if the water fill valve leaks or the ice maker is the problem and replace the offender. For the second, thaw out and clear all the ice, paying special attention to the drain located under the freezer (cooling) coil. Then clear the blockage from the drain tube. BE CAREFUL AND DO NOT USE WIRE OR SHARP ITEMS as this can pierce a hole in the drain requiring replacement, not something you want to do or pay for. A turkey baster and hot water are useful tools to flush out the blockage allowing water to drain freely into the defrost drain pan under the refrigerator.
Sep 12, 2014 | Refrigerators
What causes ice build up in bottom of freezer with french doors and then leaks out
sounds to me like a bad door seals causing condensation and leakage
Aug 23, 2014 | Whirlpool Refrigerators
My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
At times, there is water that freezes under the vegetable/fruit drawers that are at the bottom of the refrigerator. Also, at times there may be a thin layer of ice on the floor of the top freezer. I'm...
Your freezer drain is clogged or frozen up with ice blockage. Need to remove the freezer floor liner, usually 2-4 1/4" screws holding it in - slide it out. Next slowly pour hot water over ice build up and melt all ice. The drain is under the evaporator coils (small hole near center) this connects to a pan under the refrigerator that then evaporates on its own. I usually place a couple of bowls inside fresh food area on top shelf to catch excess water dripping through ceiling of fresh foods.
Next you will need to attach a heat probe from the heater under the freezer coils and feed it into the drain in order to prevent freezing up again. Use part #819043 heat probe or strip some #14 gauge copper wire and wrap around heater once and place down through drain. Recommend the heat probe 819043 to get it right the first time.
Jan 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
191 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
