Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
700P / LT782s / LT916s
Hey Omnifox,
Did you try the cap replacement on a 700P / LT782s?  And if so did it work?
Do the boards in the 700P / LT782s look like the ones in BNUTZBCRAZY's video's?
Thanks, Jetlab
  • Bobc491 May 11, 2010
    Link for bnutzbcrazy's video for LT916s?
3 Suggested Answers
  • 4 Answers
SOURCE: Mag lt782s power board problems
Is it a really fast blink on the power light? If so, you might be looking at the wrong item. The fast blink means that the mainboard has an issue.
Like I've said sever other times on this board, there's an NPN transistor that is usually the culprit. Just yank it and replace it with a Radio Shack NPN and you should be in business (maybe bump it up a touch so that you don't have the same problem again).
Posted on Nov 18, 2007
  • 100 Answers
SOURCE: No power with 700P LCD monitor, No green light,
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Posted on Jan 05, 2010
Have a Mag 19" monitor, model LT916s. Screen is
Sounds like a silly question but have you checked the fuse? If it isn't that then it sounds like a problem with the power board. Check it for burn marks and bulging electrolytic capacitors (they're the little round tube like things that stick up), also check any fuses on the board. If it's the caps or a fuse then just replace them, if something else is burnt out then you'd have to replace the board but you might not be able to find a replacement since it's old.
Feb 17, 2011 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag Innovation LT916s 900p LCD with a Horizontal twitch
That is capacitors problem, I would change all the caps in the 5v and 12v power supply section, you can have bad caps with high ESR. Also look at the caps on the logic board. I use hair dryer for troubleshooting to locate bad caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 15, 2010 | Mag Innovision 19" LCD Flat-Panel Monitor...
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
I replaced the screen in my palm treo 700p and now the phone works but the screen wont come on.... what do i do?
Can you hear it ring when u try to call ur number using a different phone? If yes, maybe it isn't aligned properly or check the connector.
If no, the software is crashed, it needs a software reflash/reprogram
Dec 15, 2009 | Palm Treo 700p Smartphone
Screen goes black after a few seconds.
when the screen goes black shine a flashlight on it. If you see a dim image the back light needs to be replaced. Otherwise check the inverter as that may be causing the problem as well.
Sep 07, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
MAG 700P monitor display goes black after 60 seconds
Can you send pictures of the power board to me at tech@ccl-la.com I will check our service manuals for the model and get back with you about a solution.
Buddy
Corporate Computer
Jun 29, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Black screen monitor
souns like the dc-dc convertor board that supplies the backlight gone faulty possible poor soldering on board
Oct 07, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAG Innovision LT916S monitor problem
Hi this is the way how to examine what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Tan
Mar 07, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Oct 12, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Computers & Internet Logo
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
