Question about X2Gen MG19MY 19" LCD Monitor
My monitor just stopped working. Could it be the
My monitor just stopped working. Could it be the converter?
  • 11,361 Answers
It can be that the power supply failed due to bad caps, failed inverter circuits due to shorted transistors or transformers, failed lamp assmblies due to burnt wires or just bad lamps.
Please look through my pictures so you will know what to look for inside if you are going to DIY repair.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 11, 2010
Help Adding a 2nd Monitor to ALL-IN-ONE
Try using a VGA to VGA cable or a dvi to dvi cable because dvi-d and hdmi tend to lack the necessary pins to be converted to an analogue signal. A hdmi to dvi cable may also work
Jun 12, 2013 | Gateway One ZX4970G-UW308 All-In-One...
My formac dvi monitor wont work as a 2nd monitor for my laptop
Try a monitor that has a vga output only, sometimes these laptops can't recognize the difference when there is a converter involved. It doesn't see the signal properly.
Try that and if a regular monitor works with vga then you know that monitor may not be compatible with that laptop because of the converter. You could also try another converter as well to see if that fixes the problem.
May 07, 2010 | Formac Gallery 2010 20.1" LCD Monitor
I have a HDM HANNspree HF207 20" and I run Vista Home Premium w/ Service Pack 2. When I run the install disk with the drivers, it says Auto Install Finished, and then a screen that says autoins(then a...
Hello
I bought a VGA to HDMI converter on Ebay. It works OK, but I prefer using a DVI to HTML adapter. As to the main problem. This has to be a driver issue. I'm wondering whether your drivers will work with Vista SP. It's the Japenese characters that are really puzzling. The Generic PNP monitor driver is the Windows resident. It's not loading your HDM drivers. I'm afraid I can't give you a definitive answer. I would like to see if this combination worked with XP. I'm betting it would.
Sorry I couldn't help more.
Sep 24, 2009 | Computers & Internet
MONITOR CONVERTER
It would require two seperate components. The first is the cable, the second is the signal converter. The cable can be found at any A/V store and the converter can be found at:
www.ramelectronics.net
MSI VGA DB15 to S-Video Convertor Cable
Specifications
Mfr Part Number: MSI-SVIDEO
Ram Electronics
Video to VGA Converter, GVM2000
$89.00
Convert your Composite Video or S-Video Signal into VGA (RGB/HV). This allows you to use a computer monitor as a display for your Standard Definition Video Source - DVD, Game System, VCR, etc.
Oct 15, 2008 | Computers & Internet
How to convert a computer monitor to video television
You need a converter box, there might be some input lag but it should be ok if you are just watching tv.
it's a RCA to VGA converter, it's a thing you buy.
Oct 11, 2008 | AcerView 54EL 15" CRT Monitor
My gateway model 900G monitor will not display an image. The on/off button does not light up and the power cord is good. What can I do?
If the on/off light is not lit, then the monitor is not receiving power for some reason.
This could be:
Power is not available, meaning the outlet maight be dead.
The power supply [power converter too, if it has a square/rectangular box as part of the powercord] for the monitor is bad, meaning it is getting power from the outlet, but nothing makes it to the monitor.
The power converter or cirucuit board in the monitor is bad nad needs to be replaced, because power is getting to the monitor, but the monitor is either not able to convert it into useable current, or the circuit board within the monitor is damaged.
You can find out which is going on by doing the following:
Grab a $10 voltmeter at your hardware store and check the power coming from your outlet, then plug the power cord/converter into the outlet and check the other end for same. Note: If your power cord has a converter on it, check to make sure the voltage/amps are the same as what is printed on the label of power converter. If those are all good, then your monitor needs repair. get a quote first before allowing any work to be done, as it could cost more to fix this than a new monitor would cost.
Jul 14, 2008 | Gateway Computers & Internet
Hp pavilion 1503 monitor lcd
Believe it or not, I got given a f1503 not working but without the power cable. He said the same thing everyone else is saying. I did not have a 12 volt 3amp converter but a 12 volt 1.5 amp converter. Plugged it in turned it on and wow it worked fine. It has been working for 1 week on with no problems. So try a different power converter, worked for me.
Jul 06, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
LCD is dead. CPU still works. Need to know what to press to convert my picture
why not use the VGA port and plug it in any monitor. even without pressing anykey you can PLUG the monitor *(external) first in the laptop before you turn the laptop on. By default the laptop should boot into the monitor you have attached.
Hope this helps
Apr 07, 2008 | Toshiba Satellite A105 Notebook
My dvi receiver doesnt work
You need to go to a computer store and pick up a new DVI adapter, there usually around $8. Try this, its the cheapest thing to try first. Also, make sure the monitor isnt set to anolog, it needs to be set to digital.
Feb 23, 2008 | Acer AL2032wd (Black) (Black, Silver) 20...
White screen covers desktop
Ah A simple one. simply unplug the power adaptor and take itno a repair place or radio shack and ask them to measure the output to see if theres 12 volts DC on the plug?? Good Luck
Jun 14, 2006 | Princeton Digital LCD17 17" Flat Panel LCD...
X2Gen MG19MY 19" LCD Monitor Logo
77 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
