Question about Sharp EL-506WBBK Calculator
I have a solar panel Sharp calculator and the model is EL-506W.The calculator was covered and under the pressure of some books, the hyp, sin, cos and tan buttons now do not work when pressed. How do I get these buttons to start back operating again?
  • Sharp Master
  • 7,993 Answers
If there is NO physical damage to the calculator, you can use a straightened paper clip or the tip of a ball point pen to press the RESET button on the back of the calculator.
Posted on Jun 14, 2010
Have a sharp EL-506w calculator i have ten zeros on the screen it will do problems but it s a bunch of zeros behind it it aiso says x10 in small context at the far right side bottom of the screen.
Your calculator is set to display in scientific notation. To change it, press SETUP 1 then choose the desired mode. For most purposes you'll probably want Floating Point. For more details see the third column of the first page of the manual.
Oct 22, 2012 | Sharp Office Equipment & Supplies
What does the eng,in,sin.cos,hyp,rcl,abs
You sure will benefit more from your calculator by taking a look at its manual. After all that is what it was created for.
No matter. I am willing to presume that if you are asking about these keys that is because you have not seen the relevant functions yet in your Math courses. One day or another (soon) you will know about them, and I will not go into explaining what they are or what they are used for. (Awfully SORRY)
  1. ENG signifies engineering notation (No I will not explain what it is).
  2. SIN, COS, and TAN are the keys for the trigonometric function sine, cosine, and tangent.
  3. HYP is entered before a trigonometric function key to calculate its hyperbolic counterpart : the hyperbolic sine (HYP SIN), the hyperbolic cosine (HYP COS), and the hyperbolic tangent (HYP TAN).
  4. RCL followed by a letter recalls a value stored in memories, A, B, C, D, M.
  5. ABS takes the absolute value of an expression.
  6. IN, I do not know, but it might be LN for natural logarithm.
Feb 19, 2011 | Casio FX83ES Scientific Calculator
What do the symbols like log ,abs,hyp,sin,cos,tan,rcl,m+ ang eng stand for
log - logarithm abs - absolute value
hyp - hyperbolic function sin - sine cos - cosine tan - tangent rcl - recall variable value m+ - memory in eng - engineering notation
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
How do I put in sinh on my casio fx-300ms calc
To get sinh press HYP then SIN
To get inverse hyperbolic sine press HYP SHIFT SIN
To get cosh, press HYP then COS etc.
Ex sinh 3.6 HYP SIN 3.6 =
Ex sinh^-1 30 HYP SHIFT SIN 30 =
Aug 18, 2010 | Casio FX-300MS Calculator
How do i do a fraction on my calculator
ok i figure this is like any other calculator, but without a fraction button. A fraction i somthing / something . so instead of the fraction button use the division button.
Jul 07, 2010 | Sharp EL-501WBBL Calculator
What is d use of hyp function??
The hyp key is used with the cos, sin, and tan keys to compute the hyperbolic cosine, hyperbolic sine, and hyperbolic tangent functions (and their inverses).
The hyperbolic functions are computed the same way as the trignometric functions: simply press the hyp key just before pressing the desired trig key.
May 04, 2010 | Casio FX-300MS Calculator
I have a Sharp EL-531W.All keys work except for sin cos tan hyp.
No solution, but I have the exact same problem with a Sharp EL-531W calculator. Doesn't matter whether mode is degrees, radians, etc., and resetting with button in back has no effect.
Feb 26, 2010 | Sharp EL-501WBBL Calculator
Step by step ho to Convert Fractions to decimals?
No post is an adequate substitute for reading the manual. Here is the meaning of some of the primary keys.
  1. hyp.: To calculate hyperbolic functions: hyp + sin calculates the hyperbolic sine, hyp + cos calculates the hyperbolic cosine, hyp + tan calculates the hyperbolic tangent (sinh, cosh, tanh)
  2. sin. To calculate the sine of an angle
  3. cos.To calculate the cosine of an angle
  4. tan. To calculate the tangent of an angle
  5. yx : y with raised x, calculates general powers
  6. ln: calculates the natural logarithm (log in base e)
  7. log: calculates the logarithm in base 10
  8. ab/c : used to enter mixed fractions; 13 ab/c 7 ab/c 5 enter the mixed fraction 13 and 7/5
  9. x10 to the X : calculates the exponential function on some calculators. used to enter powers of 10 as in scientific notation; 6.02x10^23 is keyed in as 6.02 EXP 23 (Avogadro's Number of Chemistry and Physics)
  10. (-).: This is the change sign. It negates the value of a number. If a result is positive it makes it negative, and if it is negative it makes positive
  11. deg ' " : used to convert between decimal degrees and degree, minute, second.
  12. rcl : used In conjunction with a memory location, recalls the contents of the memory ( if there is one memory M, extracts what is in M and displays it)
  13. sto: used in conjunction with the name of a memory register, stores a result or an entry in the relevant memory.
  14. M+ adds the content of the display to the constant memory M
Jan 13, 2010 | Casio FX-115ES Scientific Calculator
Sharp EL-506WBBK Calculator Logo
257 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
