Question about HP OfficeJet 6110 All-In-One InkJet Printer
TELEPHONE HOOK-UP REQUIREMENTS
Is there anything special required to hook-up the telephone to the Model 6110 HP Printer, FAX Copier machine ???
  • 241 Answers
Just a plain telephone cord, plug it in. Go into setup and setup your fax name and number that will appear on the fax your sending. Set the number of rings before answering. Place a test fax call to some fax machine.
  1. Send a one page black and white text fax to 1-888-hpfaxme (1-888-473-2963).
  2. When your fax is received by the HP Test Fax Service, we will generate a return fax to you within five minutes confirming that we received your fax. This verifies that you can both send and receive a fax with your fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Consult the user manual that came with the product for proper setup and configuration.
Posted on May 11, 2010
How to hook up fax on HP C7280
The C7280 can be used as a stand-alone fax machine. All you need to hook up to the printer is a telephone line. Connect the phone line to the jack marked "1-Line" on the rear panel, below the power supply connector. If you want, you can connect an extension phone to the jack marked "2-Ext". The line connection is for a standard telephone line. Once the line is connected, faxing is pretty much the same as it is on any fax machine. Put your documents face up in the feeder on top, or for a single sheet, face down on the scanner glass. Press the "Fax menu" button on the control panel and you'll be asked for the number. Enter the number from the keypad and then press the "Start fax black" or "Start fax color" color button to send the fax. Other than the phone line, there isn't anything else you need to hook up.
You can download the manual from HP if you need it for reference. It explains how to use the special features of the fax machine, like broadcast faxing, memory dialing, printing fax reports, etc.
Aug 17, 2011 | HP Computers & Internet
How do i find out the phone number for my dsl line so people can fax to me
Are you using Single line with 2 seperate no. for Telephone and Fax ? If so, You can contact the Telephone provider to check the Dedicated No. for Fax ( Usually Called as DRP [ Distinctive Ring Pattern ] or special no. on the same line )
There is a way to set this up on your printer. you have to set the DRP on printer under Fax Settings DRP.
Jun 23, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I just Bought the HP Officejet All-in-one J4540 Printer. I am also using Vonage as my phone source. I have high speed broad band internet cable. How must my phone jack hook ups be configured to send and...
Since a fax works over an analog telephome signal this is no different when you hook up a phone to your vonage. I believe you hook up a regular telephone to your vonage router via a telephone jack in the back of it. If so plug the fax machine into it via a splitter
Nov 25, 2009 | Office Equipment & Supplies
I have a HP officejet 6110 all-in-one and I cannot fax a document. It works but i had to hook my new PC and I might have gotten my phone wires crossed. I am using modem high speed internet and I was able...
HI,
ITS PROBLEM WITH URS RJ11 TELEPHONE CONNECTOR,
CHECK RJ 11 CONNECTOR WITH OTHER TELEPHONE,IF U HEAR DIAL TONE THEN PHONE LINE IS OK,I T MIGHT BE PROBLEM WITH URS PRINTER FEMALE CONNECTOR RJ 11 CONNNECTOR,
APPROCH PRINTER TECHNICHIAN...
TNKS
RABBANEES
Nov 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
It says the phone is off the hook but it's not. I
hi there!
i have seen the article below that may help you deal with the error. It contains diagnosis and troubleshooting procedures. Hope this helps!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00322712&cc=us&lc=en&dlc=en&product=441125
A Phone Off Hook message may notbe an error. It simply indicates that a telephone receiver is off thehook (the handset is lifted) and the telephone line is open.This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • Telephone Answering Machine using the phone line.
  • TheStart Fax button was pressed with no telephone number entered. PressingStop or Cancel should return the display to a ready state.When the other device is no longer using the phone line, the display should revert to the normal message.
Nov 05, 2009 | HP Officejet Pro L7680 All-In-One Printer
Setup fax machine with new telephone number
no change is needed for incoming faxes (it your new number) and the person (s) on the outgoing side will see the new number also....so just connect it correctly and happy faxing
Mar 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Unable to use Fax machine with cable company telephone.
You don't have the cable plugged into the "telephone" jack instead of the "line" jack on the machine do you?
Mar 13, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Will not send faxes
Make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to add a telephone to the fax. If it is connected properly, try calling your fax from a cell phone and see if it answers. If the fax answers, hang up and press the HOOK button on your fax and use the fax keypad to call your cell. If the cell rings, answer the call and listen for the fax machine tones. If you hear the fax on the cell, you may have to change your machines TRANSMIT or DIALING settings.
Jul 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Outgoing fax
Plug the phone cord from the wall into the port marke "line" and not "phone".
Jan 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
212 people viewed this question
Seeker5211
Seeker5211
