Question about Epson Perfection 3170 Flatbed Scanner
Red light flashes/scanner makes a clicking noise and won't scan
I tried to scan from a large book and the scanner got stalled and I believe I have damaged the yellow strip that you see when you open the scanner and which, I believe, moves the scanning mechanism back and forth.
Thanks anybody!
  • jetrohr May 10, 2010
    Thanks but I don't see any solution. I think it must be a mechanical problem and probably needs a repairman or, perhaps, a new scanner.
  • 787 Answers
Do you get any error messages (on the computer) or do any of the leds blink? If yes, please tell me so that I can troubleshoot and propose solutions. If the scanner behaves normally (just like when it was working fine) then yes, you need to take to a repair shop to have it checked and repaired. However, please ask for a quote before the repairing starts, it may be cheaper to buy a new scanner.
Posted on May 11, 2010
  • Epson Master
  • 12,061 Answers
Http://support.epson.ru/products/manuals/000770/p3170sg_e.pdf
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=25021&infoType=Doc
http://www.scrippscollege.edu/campus/it/pdf/scanning/epson-perfection-tips.pdf
Ok, above is a troubleshooting guide, above that is a support document above that is a user manual.
http://tech-manuals.net/canon-laser-class-3170-3175-service-manual-p-274.html
http://www.smpcshop.com/CLX-3170-CLX-3170N-CLX-3170FN-CLX-3170FW-CLX-3175-CLX-3175N-CLX-3175FN-CLX-3175FW-p-8669.html
Above is couple of, Service and repair manuals, unfortunately, it is a "Pay For" link, I was unable to find any free manual. You simply cannot effect any repair without a service manual, as they have not only all the servicing data, but also the part Numbers to obtain new spare parts..
Posted on May 10, 2010
Scanner mechanism stuck, making loud clicking sound
I've just got this problem after a powercut, whilst it was not being used but on. If you have only had it a few months send it in warranty.
Think I will have to take this apart and see if the scanner cable/ribbon/drive belt is caught on something or been stretched too much and can be replaced at all.
Its like at one end its caught and wont move the scanning head being stuck somehow, caught on something (doubtful tho').
Apr 14, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Red light flashing on power button after attempting a scan, making a funny jerky sound like a jammed mechanism
Found online epson manual, found that lock tab on the back of the scanner had been bumped across to "lock" position.
Jun 18, 2009 | Epson Perfection V700 PHOTO Flatbed...
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
Red light flashing and noise
The user manual states the flashing red light signals that your transportation lock is on. Look underneath the scanner and you'll see a switch for "lock" and "unlock." If the switch is turned to "lock" move it over to "unlock" and plug the usb cable back into your computer. It should work with no flashing red light. If not try restarting your computer and plugging it back in again.
Mar 30, 2009 | Epson Perfection 2480 Photo Flatbed...
Canoscan 4200f clicking noise when turned on
Cool. I bought the scanner 2-3 years ago and i had the same problem. I gave it back, received a new one ... exactly the same noise ... on 3 different computers. **** product!
Jul 30, 2008 | Canon CanoScan 4200F Flatbed Scanner
Problem with new set
Sounds like the lock-switch is in the locked position. This is on the bottom of the scanner. Move the lock-switch back and forth a few times and then leave it in the unlock posotion. Try scanning again.
If you are scanning a book, it may be too heavy and putting enough pressure on the scanner that it is preventing the scan head from moving fully. Try scanning with nothing on the glass to see if it does the same thing.
Mar 27, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanner will not connect to PC
Make sure that the scanner file utility is running on the computer you are scanning to. Go to Start - Programs - Scanner User Software - Scanner File Utility. It will open in the system tray by the clock on the PC. Try to scan again. If still have the same error, go to the webpage of the scanner (just enter the IP address of the scanner NIC in Internet Explorer. Go to the bottom left side of the page and click Scan to PC Destination List. Click on the number to the left of the name you are scanning to. check the IP address listed on the webpage and make sure it matches the IP address of the Computer you are scanning to. One of these should fix it.
Please remember to rate you answers.
Dec 28, 2007 | Kyocera CS-2550 Black and White Copier
Awful noise
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (the plastic switch at the back of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Oct 16, 2007 | Epson Perfection 4180 Photo Flatbed...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Epson Perfection 3170 Flatbed Scanner Logo
213 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
