Question about Whirlpool Duet GHW9150P Front Load Washer
Leaking whirlpool duet washer front load
I have a front load whirlppol duet. It leaks through the door when the clothes seem to rotate in the drum. As soon as the clothing rotates and hits the bottom of the drum the water comes out the bottom of the door.
  • Anonymous Mar 23, 2014
    machine will run completes cycle but drum doesn't rotate
  • 185 Answers
Remove and clean any obstruction or deposits around the inner door seal use H.E. detergent over sudsing can cause that too.
Posted on Mar 28, 2008
My 4 yr old Whirlpool Duet front load washer is leaking water onto the floor from the bottom of the machine. It seems to be coming from underneath or back, it is not coming through the door. It's not...
The most frequent place for a front-loader to leak is on the door connector boot. The boot connects the drum to the door. You can often remove it and replace it upside down and that will give you a few more months' use.
Jan 23, 2015 | Whirlpool Washing Machines
My washing machine is leaking
Through the door? Where is it coming from?
If door, check the rubber seals are ok and not torn, broken or perished.
If elsewhere, could be a break in the drum or a water pipe loose
Oct 14, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet (Model # WFW8400TW02 )washer stopped working. the steel drum is not rotating and clothes are not getting washed. please let me know what could be the problem.. --Ritu
If this has a belt, then the belt may be broken or stretched out. Bad drum bearings can seize up and won't let the drum rotate anymore. A bad door switch can cause the machine not to run.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a front loading whirlpool duet washer and the door seal is damaged and water is leaking out at bottom of door. Is this easy to fix/
this is not a hard thing to fix just a little time consuming.there is a spring under the edge of the boot that needs to be removed,
Then you will need to remove the front panel,so that you can remove the other spring that holds it to the drum.
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Leaking
For those wondering about replacing the water inlet valve - this is a very simple undertaking.  You can find the part online for around 40 bucks.  All you have to do is unplug the washer, detach the hot and cold supply hoses, remove the lid (3 torx bits on my model) unhook the water line from the old inlet valve (conveniently accessible at the top right of the unit from the rear), unhook the electrical connections (be sure to label these for later re-attachment), unscrew the 1 screw holding the valve in place, and reverse the process with the new valve.  I'm hoping this will stop water accumulating in the drum - I'll update later if it does not.
Jan 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,036 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
