Question about Raypak BURNER TRAY W/VALVE NAT 335
Heater cycles on and off continuously - Raypak BURNER TRAY W/VALVE NAT 335
    Top Expert:
  • Raypak Master
  • 8,674 Answers
Check gas pressure if ok check flame sensor
Posted on May 25, 2016
Hot tub pump running unexpectedly
check the heater setting.. it may be the heater demanding cooler water to go through..it will cycle as needed by the heater..
Dec 27, 2013 | Pool & Spa
Hotpoint
Most dishwashers require heater to acheive a pre set temperature before continuing the cycle, if temp if not acheived then often machine will continue on its current cycle (ad nausium) untill temp is acheived, if heater is not working then this of course will never happen, most heaters are visable in base of washer interia, take a look ,is there any damage that you can see.it can be fixed, and heater replaced if necessary.
Feb 18, 2013 | Dishwashers
My wmd 1050 front loader won't continue with its cycle. It fills, does a few turns, empties and finishes., all in a few minutes. It doesn't seem to wash but will spin dry when manually put on a spin dry...
Are you sure the machine is not overfilling? next step after filling would be water heating - sounds like a water heating problem if machine spins and drains ok. Maybe a coin in the wash has punctured the element? water heater can be test for insulation / continuity if you have a high voltage tester, or remove it and examine if not by releasing the nut and pulling firmly. If it is scaled, holed or black replacement will be needed. Sometimes socks or clothing stuck on the heater cause localised overheating that will make it fail.
Dec 16, 2017 | Electrolux Washing Machines
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dryer won't heat up, what do we do?
You will need to check for the vvoltage to the heater during the cycle. use a multimeter to check the continuity of the heater, if open the heater needs a replacement. If the heater is testing good then the controller is not outputting the voltage to the heater during the cycle . A possible break, a contact or an open connection must be checked with the meter, tracing back.
Sep 12, 2010 | Whirlpool LER5636P Electric Dryer
My Dishwasher is DS603 and it stop on minutes 26 during a cycle and never continue.
Hi- sounds like your heater plate is bad. The cycle wont continue unless the water reaches a specific temperature for that point in the cycle.
Mar 08, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Running time of dishwasher
he cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
The cycle doesn't complete If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Mar 14, 2009 | Bosch Dishwashers
The power vent blower on my hot water tank will not shut off.
If the blower continues after the end of the burn cycle it is the cool the heater down. Over running would indicate a defective end cycle temp relay.
Good Luck, Phil
Nov 14, 2008 | Water Heaters
Cycle runs for 2-3 or more hours
If your dishwasher's cycle times are too long, check these: Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
Cycle not completing f the cycle doesn't complete, check these:
Oct 23, 2008 | GE Nautilus 24" Built-in Dishwasher
Raypak BURNER TRAY W/VALVE NAT 335 Logo
57 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
