There are series of problem
in xbox 360 which can be solved without much technical knowledge ........ your
problem belong to that so dont worry i will give you the link to download
the xbox 360 repair guide that will help you a lot Click
Here
This means your system is broken,and u will have to send it in for repaires, but all you have to do is contact Xbox 360 customer support and they should send u a pre-paid postage ( they will e-mail it to u ,so all u do is print it out and attach to package).This is all done for FREE!!! you will get your repaired or replaced 360 in about a week or so after you send them your broken unit...QUICK FIX make sure all of the connections are plugged in all the way ! If all else fails u can wrap your 360 in a blanket covering all vents and let heat up until it shuts off automaticly or 3-4 hours... when you turn the 360 off or it shuts off on its own let it cool down at least an hour...then turn on power and hopefully it will have reset and you will have all green lights.Good luck!
