Question about Uniden Cordless Phone
All four phone are stuck on out of range. How do I get them to work again?
  • 241 Answers
Try removing the batteries from each phone for a few minutes and reinstalling them.
Posted on May 10, 2010
Imitsubishi shogun engaging 4 wheel drive
no year?
never drive, part time 4wd on pavement, unless said pavement
is ice or snow covered.
only AWD allows pavement (tires direct upon) driviing.
part time 4wd is for offroad , off pavement driving,
this is because 4wd has no center differential.
http://en.wikipedia.org/wiki/Four-wheel_drive
and with out such, winds up the drive line fast. and breaks it.
wiki states (no year stated by you)
Part-time four-wheel drive was standard on all models. to 1991
then came
ActivTrak 4WD
cept
4H (high-range full time four-wheel drive), 4HLc (high-range four-wheel drive with locked center differential) and 4LLc (low-range four-wheel drive with locked center differential
so do not use LOCKED on pavement. on active track. only 4H
the wiki states the Super-select is retained 2006 to present.
Super-Select 4WD II
read the glove box manual under 4wd
Oct 16, 2013 | Cars & Trucks
I have a Motorola H350 ear piece I lost my inst. manual and do not have a pass key
Hi, If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
Feb 16, 2011 | Motorola Mobility H350 Wireless Headset
My magic chef stove model#31100paw oven will not heat up but all four stove burners are working just fin.what is going on?
This oven and range work from two separate regulators and it sounds like the one for the oven has failed. Have it replaced and that should get you going again. Hope this helps. Good luck.
Mar 15, 2010 | Magic Chef 31000 Gas Kitchen Range
Burners do not ignite
I decided to remove all the parts again and reassemble completely, including the grills. They worked again!
Jan 15, 2010 | Hotpoint RGB745 Gas Kitchen Range
Every phone has handset
All four phones showed "Out of Range" I unpluged the main phone - the one with the telephone hook up. I left it unpluged for a few minutes, plugged it in and IT WORKED> Thanks for your interest in helping me.
JJS
Nov 19, 2009 | Uniden 2.4 GHz Cordless Phone System
Handsets read Handset Out Of Range
Disconnected power and phone line, reassembled and then had a dial tone.
Mar 23, 2009 | Uniden TRU9585-4 Quad Cordless Phone
Ou t of range
i just fixed mine! hold # and * together let go and do it again, it will reset.. you will be able to make calls again
Dec 29, 2007 | Uniden TRU8885-2 Cordless Phone
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Out of range
I have a Radio Shack 2.4ghz cordless phone system and sometimes the handsets will show "Out of range".
My Solution that works for me.
Unplug the power cord and telephone line to the base for about 30 seconds. This seems to reset the base. Then plug everything back and you should be ok.
ET Sherman
Oct 07, 2007 | Panasonic KX-T7730 Corded Phone
Uniden Cordless Phone Logo
61 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
