Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
WD440G. No heat in wash and dry.
Hey guys, my washer/dryer has no heat in wash and dry modes. I know they are seperate heater elements, and was just wondering wether both have gone at the same time or if there could be another reason? Cheers.
    Problem Solver:
  • 8 Answers
I would first check exhust vent to make sure it's not clogged if so it will cause your heating sensor to shut down
Posted on Apr 03, 2008
SOURCE:
Hotpoint WD440 washer/dryer wont control.when plugged in 4 lights flash and it goes to pump out . no switch has any effect. the lights flashing are the on/off ,drying high heat.reduced creases and time...
The NTC for the dryer is situated on top of the dryer heater box, fault can often be caused by a simple broken wire, they are very weak at this point.
its the sensor on the dryer
if you take off the top, its mounted on top of the dryer box, usually has a white plug with 2 black wires attached
Dec 13, 2011 | Hotpoint Ariston WD440G Front Load...
I have a Hotpoint Aquarius WD420 washer/dryer that is not heating the washing water, yet does heat when in drying mode. Does the machine use the same heating element for washing and drying, or are there...
There is a seperate element for the water heater. so likely to be a faulty heater or thermistor which is fastened toi the element
You really need a test meter to determine which part is faulty.
Dec 27, 2010 | Hotpoint Washing Machines
MY BEKO WMA520W WASHER DOES NOT HEAT WATER UP
you need to check Heater element it should read about 32 ohms if ok on a multimeter, next the thermostat should be closed circuit, any loose wires....Hope this helps.
Apr 20, 2010 | Hotpoint Ariston WD440G Front Load...
Dryer runs but does not get hot and dry
It runs since the motor is still working and turning the drum. No heat since the heater element is broken so no heat got produced to dry clothes. Replace the heater element to correct the problem. Good luck
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
No heat during drying cycle
your heating element or the thermostats that control the heating element could be bad. research no heat for your make of dryer, it should show how to ohm the thermostats and element for fault. They should all read 000 when ohmed. 000 being a complete circuit. I have been having thermal fuse problems with my whirlpool dryer, so I'm learning as I go.
Oct 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Hotpoint WD440G In wash cycle and blows all household plugs
syphon out the water by getting the end of the drain hose into a basin and putting it lower than the water level. a few shakes usually gets it flowing. you probably have a short circuit. my guess would be the heater box/element to start.
Jan 30, 2009 | Hotpoint Ariston WD440G Front Load...
Wd440g Hotpoint - in wash cycle and is blowing all the household
you will have a short circuit somewhere. usually the dryer box, but to get the water out you need to put the end of the drain hose lower than the water level into a basin to syphon it out.
the heating element of the dryer sometimes come loose on these machines and can be the cause of a short.
Hotpoint wd440 washer dryer fault
sounds like the heating element of the dryer may have come loose and is shorting against the metal dryer box on top of the drum.
engineer job if you're not electrical
Jan 25, 2009 | Hotpoint Ariston WD440G Front Load...
Washer dryer not heating up
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Oct 23, 2007 | Hotpoint Aquarius WD640 Front Load...
Hoover nextra 5+5 washer dryer HNWF 3135 heating broken
it is seperate heaters for wash and dry and unlikely to be connected with blocked filter tho you should check filter regularly. take top off. on manifold running across top you will see stats. one of these at least is resettable by presssing a small knob in middle and if it has gone you will hear a slight click. then check dryer manifole for build up of lint as pooir air flow can cause stat to pop. for wash heating, start by checking continuity of the wash heater located at the bottom of the tub
Nov 04, 2006 | Hoover Nextra HNWF 3135 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
104 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
