Question about Craftsman Garden
Despite replacing batteries for lawn trimmer, the trimmer goes too slow to cut grass.
    President:
  • 2,702 Answers
I would say the drive motor has seen better days,,,it would be cheaper to get a new one that try to get yours fixed up
Posted on May 10, 2010
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
Cst trimmer wont cut grass
buy a new battery or if there is a batteries Plus store near your location they might be able to rebuild the old one for about 1/2 price of new
Aug 28, 2015 | Black & Decker Garden
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
When my flymo lite 250 engine is running the end does not turn to cut the grass
Could be anything from a stripped drive shaft to a loose or stripped trimmer head. You'll probably need to take it to a repair shop to have them diagnose the problem and locate the replacement parts if it's anything other than a stripped trimmer head bolt.
Nov 01, 2011 | Homelite Mighty Lite Lawn Trimmer
How to put together a black n decker grass trimmer,has assembled the trimmer it's not cutting the grass should there be a blade in the trimmer
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Oct 12, 2010 | Black & Decker 14" Grass Hog Xp...
My whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Mar 01, 2010 | Garden
B&D grasshog XP motor squeeled and spin rate slowed. repairable?
I just saw your post. Check the area between the housing and the head, along the shaft. Fibrous debris (in my area, this loosely translates into "lilly leaves") gets wound around the shaft, and will slow the universe down to a crawl. The only way to get it loose is to cut it loose, or unwind it.
Best regards, --W/D--
Aug 18, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
