Question about Maytag MZD2766GES Side by Side Refrigerator
My ice maker is not working, the lock is not on and it is in the on position to make ice. My model is the MZD2766GEW
  • Maytag Master
  • 4,654 Answers
We can test the ice maker if the ice slots are empty by filling with tap water. After the water freezes and if the ice drops the the ice maker is OK. The dual water control valve for the side that feeds the ice maker could be the problem or the ice maker module part 7824706Q Let me know what happens and I will return with links and photos, Thanks Sea Breeze
Posted on May 11, 2010
  • John Tripp
    John Tripp May 11, 2010
    If you find that the ice maker does not work after the test the part Click Here=> 7824706Q will be your best bet. The small parts are too expensive unless you rebuild them every day.
    Your model came with two types of water control valves, one for a water filter setup and the other is standard. You will see the difference. Click Here for the=> 61005626 Dual Water Control Valve And the other is part number Click Here=> 12001892
    Replacement ice maker assembly used on some Amana brands refrigerators. Does not include wiring harness, cover or mounting hardware.
    Or you can go here=> Appliance Parts Southeast and click on any picture and then enter the same part numbers. And sometimes local parts are easier to get. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Thanks, Sea Breeze
  • John Tripp
    John Tripp May 12, 2010
    Did you get my links and photos?
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
Where do I turn ice maker off and on? I have misplaced owner's manual on model gss251frf ww.
Ice makers make ice until the ice bin is full, and as you use the ice, it replaces what is used. This is accomplished by a wire that measures the amount of ice in the bin. The wire moves up and drops the ice and then moves down to measure the ice. If the bin is full, the wire will be held in the "up" position which turns the ice maker off. You can manually lock the wire in the up position and it will never make ice. Releasing the wire will start the ice making process.
Jan 18, 2012 | GE Refrigerators
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 28, 2011 | Maytag MZD2667HE Side by Side Refrigerator
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
Icemaker stopped working suddenly. Water supply is working fine.Ice freezes but will not dump into bin.
Good day,
If the ice maker is the style with a wire to turn it off and on, and is in the down position, then the ice maker is bad, as long as the temperature in the freezer is 12 degrees or colder.
(The ice maker locks out at about 14 degrees or warmer.).
You can replace the module, and thermostat in the the ice maker, but could be as well the mold heater.
The price of repair is so close to a complete ice maker, that it doesn't pay to repair.
You might want to get the complete model number. Check with any decent size appliance parts house, they should have what you want, if going to Sears is an issue.
Feb 04, 2010 | Kenmore Freezers
Hi! My icemaker isn't making ice. I made sure the
Check for piece of ice stuck in maker not allowing movement
Aug 07, 2009 | Refrigerators
Ice maker not getting water after changing filter
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
The ON/OFF switch is located on the top right side of the freezer
compartment.
To turn the ice maker on, slide the control to the ON (left) position.
To manually turn the ice maker off, slide the control to the OFF
(right) position.
NOTE: Your ice maker has an automatic shutoff. The ice maker
sensors will automatically stop ice production, but the control will
remain in the ON (left) position
REMEMBER:
 Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
 The quality of your ice will be only as good as the quality of the
water supplied to your ice maker. Avoid connecting the ice
maker to a softened water supply. Water softener chemicals
(such as salt) can damage parts of the ice maker and lead to
poor quality ice. If a softened water supply cannot be avoided,
make sure the water softener is operating properly and is well
maintained
The Dispenser Lock (on some models)
Your dispenser can be turned off for easy cleaning or to prevent
unintentional dispensing by small children and pets.
NOTE: The lock feature does not shut off power to the product, to
the ice maker, or to the dispenser light. It simply deactivates the
dispenser levers. The ice and water dispensers will not work.
Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
UNLOCK button to unlock the dispenser.
Style 2: Press and hold the LOCK OUT button to lock the
dispenser. Press and hold the LOCK OUT button a second time to
http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
No water is going onto the ice maker (Maytag Model # MZD2766gew)
the water solenoid valve is normally triggered by the ice maker itself. as it turn to harvest the ice, it should trigger the water solenoid valve to start another cycle of ice making. its either a wire harness problem that's why power is not getting to the valve or the triggering switch of the ice maker not sending power to the solenoid. i hope i was able to help you guys...
Jan 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag mzd2766gew icemaker
Sounds like you have a bad motor module on the icemaker. Part # is W10122536
Jan 05, 2008 | Maytag MZD2766GES Side by Side...
Ice maker LG side by side
What is the model #? Get it off the sticker inside the refrigerator side.
Oct 08, 2007 | LG LSC26905TT Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
280 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
