Question about Kenmore Elite Oasis 27052 Top Load Washer
My wfe's diamond cross necklace fell between the drum and machine
It is between the drum and plastic casing surrounding the drum. is there a way to pop the top on the machine not just the lid?
    President:
  • 1,033 Answers
The top should be held in place with metal clips that insert into the machine. A flat head screw driver will work to pry around the top. You may have to take a few screws out the backside that connects the top to the bottom.
Posted on May 10, 2010
Is the article true which is titled Hide the necklace with the cross on it?
Hi shirley.
i have a had a look around the internet and i can not find anything about it,but if you want to have a look your self then go to this link.
Hide the necklace with the cross on it Google Search .
or this one.
Is the article true which is titled Hide the necklace with the cross on it...
Oct 31, 2017 | The Computers & Internet
I think my necklace fell thru the holes of my Kenmore 70 series washing machine. How can I check if it is under the drum.
The link to the video will show how to gain access to the inside of the washing machine. I did not create the video.
Follow the safety guidelines in this video and those that came with your machine. This may well be a two-person project, especially if the machine is installed in tight quarters.
  • Take your time.
  • Be safe.
  • Use the proper tools.
  • Do not get frustrated and break any of the parts, after all, you want the machine to function again after you find your necklace.
Take pictures of screws, brackets, covers, etc. before you remove them to make reassembly easier.
You may be able to see your necklace and remove it without disassembling the washer as fully as described in this video. To be prepared for that have the following on hand:
  1. flashlight
  2. GrabEasy Grabber and Retriever PF0401 The Home Depot
    (I have a similar tool and use it frequently)
Whirlpool Kenmore Top Load Washer Disassembly Washing Machine Repair Help
Dec 16, 2015 | Kenmore Washing Machines
I have an aamco 4000 brake lathe, the disc feed is not working
The cross feed drive shaft is connected to the cross feed spindle via a coupling that resembles a universal joint that is threaded onto the end of the cross feed spindle. Either one of the roll pin holes in the drive shaft coupling has worn and the roll pin fell out or it has broken, or the coupling could have came un-screwed from the cross feed spindle. Remove the 4 bolts that hold the cross feed gearbox on and slowly pull it away from the machine and you should see the coupling I'm describing. My guess is that the roll pin broke or fell out due to wear. You can buy a new drive shaft and coupling or drill and install the next larger roll pin. Either way you should download a parts list for your machine. Just search for it, they can be downloaded free.
Aug 22, 2012 | Ammco Combination Disc/Drum Brake Lathe
My diamond necklace fell into my heater vents. I was able grab the chain in time but the diamond fell down into the vent. How do I get into the dash AND the heater vents to retrieve my diamond?
A Ford dealer might be able to help you. The vent heat and air goes down to the air heater, it you take that loose the diamound might just fall out.
Sep 10, 2010 | 2005 Ford Ranger
My daughter's necklace is stuck in the drum of my bosch nexxt 500 washer
the drum may have to be removed and taken apart in order to get the necklace out.or the chain may have to be broken and the rest ran down to the drain pump for removal
May 18, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch WFE 2021
I suggest that you check the brushes in the motor for wear.
Remove rear panel, remove drive belt, undo bolts securing motor, unplug motor lead and earth wire.
Lever motor back, keeping hold of it, and remove.
Check the brushes, they are at the opp end to the motor pulley, if there is less than 8mm left, then replace brushes.
I would also check the pump filter, and clean if req'd.
Please rate my fixya solution.
Thanks.
Feb 08, 2009 | Bosch WFE 2021 Front Load All-in-One...
Flickering display panel Boschwfe 2021
It may be the door interlock that is faulty. This is the cheaper solution however it maybe the the electonic board. In any case it needs the attention of a bosch Technician. Cross your fingers its the door interlock.
0417362396 Melbourne metro Area
Regards Sam
Jan 05, 2009 | Bosch WFE 2021 Front Load All-in-One...
Drum outlet hose assembly
Hi trevor it is just a eco ball it is not needed it will cause you more problems when it is in the machine dont worry just leave it out
Aug 01, 2008 | Whirlpool AWM8103/1 Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
263 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
