Question about Kenmore 24 in. 15684 Built-in Dishwasher
My dishwasher isn't draining completely. - Kenmore 24 in. 15684 Built-in Dishwasher
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on May 10, 2010
My dishwasher isn't draining after it's cycles.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Whirlpool DU912 Dishwasher
Our dishwasher isn't draining
Hi
Daniel
Aug 04, 2011 | Kenmore Dishwashers
My dishwacher isn't draining and make a noise..
Hi
Daniel
Jul 21, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Not draining complety
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | Admiral 18 in. DWCA500AA Free-standing...
Water does not empty from dishwasher
Hi
Thanks
Rylee
Jul 04, 2010 | Maytag MDB9750AWS Built-in Dishwasher
The dishwasher does not completely drain.
Hi
Thanks
Rylee
Jun 10, 2010 | Whirlpool 24 in. DP940PWP Free-standing...
Water won't drain
Hi
Thanks
Rylee
Jun 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher does not drain completely DU890SWLUO
Hi
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 23, 2009 | Whirlpool 24 in. DU900PCD Built-in...
Water is sitting in bottom of dishwasher after cycle is completed - fair amount of it
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | GE Profile PDW8000G Built-in Dishwasher
Runs the cycle but doesn't drain completely
Hi
Thanks
Rylee
Oct 12, 2009 | Kenmore Dishwashers
Kenmore 24 in. 15684 Built-in Dishwasher Logo
44 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
