Question about RCA D52W19 52" Rear Projection Television
My mother inlaw has a 52 in. model d52w17, it will not come on. when you push power button it will have a slight whistle 3 times and power light goes off. can you help please. thanks Mark
  • RCA Master
  • 8,617 Answers
Replace the deflection board. You should be able to get one from www.tvrepairworld.com
Posted on May 11, 2010
Push power button lights and goes out three times then stays off Will come on after two or three cycles of button pushing
Replace the three Capacitors CP150, CP120 and CP114 very common problem for that model You can get that RCA repair kit from www.tvrepairworld.com RCA and GE are the same TV.
Sep 22, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
May 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W17 wont come on, the green power light goes on and off three times then stays off.
On deflection board CK capacitor cp 150 2200uf 16v use 25v if i is puffed up on top it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v for parts call Mats 1-800-628-1118
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
WHISTLING NOISE DAY AND NIGHT IN FREEZER SECTION REFRIGERATOR GE MODEL GSS201BPDWW WHEN MOTOR IS WORKING
The whistling is caused by the air circulating fan located just behind the light. It is easily accessed by removing the light cover and the two small hex screws above the light. To stop the whistling I simply turned the freezer off and pulled the fan cover out slightly to reveal the fan blades. I then pushed the blades down, toward the bottom of the until the blades stopped and i could feel the shaft slightly protruding from the top of the blades. Repositioning the blade has stopped the incessant whistling. Hope this helps!
Apr 18, 2009 | GE Refrigerators
Will not start properly RCA D52W17
Replace CP150 , CP120 and CP114 that should take care of the Issue of hard to power up. You can get the replacement capacitors at the following link with free instructions.
http://servicemanuals.vstore.ca/
Nov 23, 2008 | RCA D52W19 52" Rear Projection Television
Power on/off
that is a common problem with this rca's check the convergence board for a short circuit
more likely is a transistor or an convergence ic
caypianan@yahoo.com
Jul 18, 2008 | RCA HD52W58 52" TV
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
201 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
