Question about JVC Everio GZ-MG630 Hard Drive Camcorder
I can not dowload to you tube, I keep getting an error message stating that "cannot connect to network"
    Guru:
  • 519 Answers
You can change another kind of software for download and convert.
Video Download Studio can be your assistant.
have a free try from http://www.downloadvideos-convert.com/download-videos-music
hope it can help you .
Posted on May 11, 2010
The screen states "searching for WiFi networks" but it is not connecting to any WiFi networks.
Are you getting any specific error message when you try to connect to one of the available networks?
For now you may find one of these of some help.
http://www.androidtablets.net/threads/steps-to-get-wifi-connected-if-having-problems.44790
How to Connect Your Android Tablet to Wi Fi Network
I post on behalf of HP.
Jul 22, 2015 | Tablets & eReaders
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
When i my pc on it show me generic host problem after this msg windows stop network services?anyone tel me
You may occasionally get an error message that reads "This connection has limited or no connectivity. You might not be able to access the Internet or some network resources." It indicates that your PC is having a problem trying to access your network device to connect to the Internet. Very often, a bug that typically affects Windows XP Service Pack 2 causes this error message. This bug causes a loss of your network connectivity in workstations that use Microsoft's L2TP-based VPN (virtual private networking) client to connect to the NAT-based networks. You can fix the "Limited or No Connectivity" problem in a few steps. (If your connection works but you still get the error message, go to Section 2 to learn how to disable it.)
Review the following symptoms and determine if you experience any of them after you install the Windows XP Service Pack 2:
You get the error message "Limited or No Connectivity" when you attempt to connect to your network.
You have a problem connecting to your local area network or to the Internet.
You keep on receiving an error message: "Acquiring IP Address" message. If you experience these symptoms after installing Windows XP Service Pack 2, then this bug is causing the problem. In this case, go to Step 2; otherwise, skip to Section 3 Download the Microsoft patch (KB884020) from the Microsoft website. Run this update to install it. Create a registry fix by launching Notepad and typing: [HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\Services\\IPSec] "AssumeUDPEncapsulationContextOnSendRule\"=dword:00000002 Save the file as FixReg.reg to your desktop. Double-click the saved file to install it into your registry. Restart your computer and the error message will likely be gone. If you still see the error message, follow the steps in Section 2. b> If Your Connection Works But You Still Get the Error Message b> Navigate to the "Start" button and select the "Control Panel." Double-click on the "Network Connections" icon. Right-click the "Local Area Connection" icon and select "Properties" from the popup menu. Click on the "General" tab. Uncheck the option that is labeled "Notify me when this connection has limited or no connectivity." Click "OK." b> If the Patch Doesn't Fix the " Limited or No Connectivity" Problem b> Check your DSL router for any malfunctions. Re-configure or power cycle your router. Check your computer's network card configurations and network cabling to ensure that the problem does not lie here. Check your firewall to determine whether it is blocking you from connecting to the network or to the Internet. Disable the firewall and attempt connecting to the network or Internet while with the firewall is disabled. If the firewall is causing connection problems, then reset or uninstall and re-install the firewall. Reduce your connection speed to 10 Mbps and test this to determine if it fixes the problem. To do so, navigate to the "Start" menu and select the "Control Panel," "System" and "Device Manager." Review the properties of your network card. Click the "Advanced tab." Locate the "Link Speed and Duplex" section. Change the settings from "Auto Detect" to "10Mbps/Full Duplex." Hope this helps.
Dec 24, 2012 | Computers & Internet
Printer keeps restarting
Perform a partial reset Perform a partial reset to restore the product settings to the default values.
1. Write down any fax numbers and country/region and language settings stored in the product memory.
CAUTION: A partial reset might remove all speed dials and other settings from the product memory.
2. Disconnect the power cord from the rear of the product.
3. Press and hold the # and 3 buttons at the same time while plugging the power cord into the rear of the product.
4. Release the buttons after 30 seconds or when Part NVM Reset displays on the control panel.
5. If the product does not turn on automatically, press the Power button ( ) to turn it on.
6. Press OK to continue the current task.
Next solution
Dowload the Firmware fix on this line. make sure it's connected over the usb cable.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3737195#N260
Critical Update to Prevent an Error State When Connecting Your Printer to a Network
2009-07-16 , Version:1.0, 789.02k
This update will prevent your printer from entering an error state and displaying an error message on the Front Panel Display when connecting to a network.
Mar 27, 2011 | HP Photosmart C6180 All-In-One InkJet...
I keep getting signed out of the Playstation Network Keeps saying error 80710A06 HEELLLPPPP!!!!
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured
This error can occur when the PlayStation Network is down, or when your router is not forwarding ports.
It does appear that the network is down, as stated here. However, you can still check to see if port forwarding is the issue.
To check if you are port forwarding, visit this site and select the router you are using.
http://portforward.com/
These are the ports needed to be forwarded:
-This may not be required if your router has an option called UPNP-
  • TCP:
    • 80
    • 443
    • 5223
  • UDP:
    • 3478
    • 3479
    • 3658 (voice chat)
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
I get a connect ok and then a connection terminated error message. [*] Connection established to 192.168.1.2, then an error message that gmail terminated the connection.
Somebody else is kicking you off of the network. Thats probably why you keep getting disconnected. Try moving your computer closer to the area or getting a new wireless card.
Nov 17, 2009 | Dell Dimension E521 PC Desktop
The network connections folder was unable to retrieve the list of network adapters
Goto Start --> Run and type (1 line at a time and don't forget to press enter or the [OK] button for each line):
regsvr32 netshell.dll
regsvr32 netcfgx.dll
regsvr32 netman.dll
After each line you should get a popup stating something like "DllRegisterServer in <file> succeeded", if not, please post the error message here. When all succeeded, reboot and check the "network connections folder", the error message should be gone now ...
Aug 16, 2009 | Computers & Internet
Unable to link a wifi enabled laptop to my wired pc and modem
Make sure that the wifi switch is on in the laptop. Look for a sliding switch in the front or side panel of the laptop. Make sure that it is on.
Hope this helps!
Nov 23, 2008 | Computers & Internet
I keep getting a printhead error....I have replaced the printhead with the canon spec printhead and I keep getting the same error message.....any thoughts?thanks,Parker
Check the wiring assemble connecting the printhead to the printer and where the wiring connects to the printer. Anything loose here would prevent the unit from correctly reading the sensors on the printhead. Just a thought.
Nov 03, 2007 | Canon imagePROGRAF W6200 InkJet Printer
JVC Everio GZ-MG630  Hard Drive Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
