Question about Lenoxx Electronics CD-102 Cassette/CD Boombox
The cd player part of my model CD 102 combo radio, cassette, cd player quit working. The motor tries to run three times, then quits. I can replace the player section if one is available. How much is a replacement cd player unit?
    President:
  • 1,851 Answers
Since the motor tries to start up, I don't think it's a motor problem. I think that the problem is at the lens; it can't read the cd so it does to stand by mode. I suggest you a cheap solution. Buy a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl
alchohol) at a specific place (like small brush) on the disk surface and play this disk. That way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropylic alchool to clean up the cd lens manually.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 12, 2010
Cd player only shows
You will need to check the swith that change from Tape to CD to other functions. If the switch is good. Then the next thing is to check for tape function. Can you try to fast forward, reverse. If these functions are working properly then the pinch roller ( the little wheel that is pulling the tape need to be replaced). If nothing moves then you need to replace the belt and the wheel and possible the motor at the same time
Nov 17, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Oct 12, 2009 | JVC Audio Players & Recorders
Audio display says check cd
This may be a bit late to help, but I just had the same problem yesterday. Same car (2000 Monte Carlo SS), but mine is just the CD/radio stereo (no cassette). I was able to solve it by pulling the fuse for the radio (it's in the right-side panel) and letting it sit for a minute. After putting it back in, the CD player made the disc ejecting sound one time (no "check CD" message) and stayed off. And now it seems to be working fine. We'll see how long it lasts, though.
Mar 25, 2009 | 2000 Chevrolet Monte Carlo
Radio & CD player just quit working and does not show time
sounds like you may need a new radio unit. the cd player runs off the radio. check your fuses first, also make sure there is a good electrical ground.
Aug 11, 2008 | 2002 Chrysler Town & Country
Left cd door not ejecting when push
Maybe the motor charge belt are in bad conditions and need a replacement or the cd sistem are out of time.Good luck
May 24, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
May 28, 2007 | RCA RCD150 Radio/Cassette/CD Boombox
Lenoxx Electronics CD-102 Cassette/CD Boombox Logo
147 people viewed this question
Top Lenoxx Electronics Audio Players & Recorders Experts
Jonathon summesfield
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
