Question about Konica Minolta Office Equipment & Supplies
Konika Minolta Copier prints half dark pages
Konika Minolta bizhub 501 copier makes half dark copies. Vertically half of every page is black and image on the other side is very light. I did not try to use it as a printer, but the test page prints out perfect, no lines no dark or light areas, so I assume image sensor or circuit has a problem. Green light under the glass is working, too. Has new toner and new drum, even though I think they are irrelevant because test pages are just as they need to be. What can be the copiers problem?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
Posted on May 12, 2010
All the copies and print outs are black colour. Why is this happening?
Have you check the gradation print out for each color in the service mode? Recommended that you do that. Does this happen in printing or copying? There is a difference. Any warning to replace certain parts? Check consumables what needs to be replaced? What does the demo page look like? Are the image units OEM? is the transfer belt OEM? Service mode + Counter, details, stop00 stop01, output, gradation pattern.
Oct 30, 2015 | Konica Minolta Bizhub C253 Copier
Just got new Konica Minolta C224 copier. Prints from computer are perfect but when I try to copy something in color it prints page with thin even cyan or magenta lines. Lines are spaced evenly about 15 mm...
MAKE SURE YOU DO EXACTLY WHAT THE INSTALLATION MANUAL SAYES, INCLUDING DOING THE"Performing Non-Image Area Erase Check" I KNOW ITS A PAIN, BUT IF YOU DONT, YOU SEE WHAT HAPPENS
Aug 24, 2013 | Konica Minolta Bizhub C224 Color Copier /...
Black lines running down on the Konica Minolta bizhub c252 copier?
Does this happen when you print? does this happen when you make copies on the big glass. Does this happen when using the document feeder?
Jan 23, 2012 | Minolta Office Equipment & Supplies
Minolta bizhub 222 dark copies
Whenever you ask about any problem please explain in detail.There are couple of reasons behind the above mentioned problem.Its not clear that copies are all black (full black) or just dark in print density? or its giving a dark shade? As per asked question, the solution is Check the followings1-Scanner mirrors are dirty2-Drum is damaged or faulty3-Charging corona 4-LD unit5-Developer
Aug 19, 2011 | Konica Minolta Bizhub 222 Black and White...
Hello mine is really an FT3713
This sounds very scary...
Your Machine is very old..
What did you do last to the Copier to get it in this condition?
All you should have done is empty the Waste Toner bottle, and do SP83.
Oct 26, 2008 | Ricoh FT3713 Copier
494 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
