Question about Vacuums
Fantom Sweeper Belt problem
Why does the drive belt on my Fantom sweeper get hot?
  • 807 Answers
Maybe it's stretched and is slipping causing friction and heat.
Try a new belt.
Posted on Mar 28, 2008
Switching new belt for old on older model 3550 Bissell vacuum. Where does belt go and does it go around sweeper bar?
If it has a belt it goes around the sweeper part and connects to the motor.
Dec 03, 2012 | Vacuums
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Vacuum wont spin when on carpet but will spin if tilted off the carpet
Remove the bottom plate of the sweeper. Remove the sweeper brush roller and clean the end bearings of debris. Oil the bearings lightly with 3-1 oil or similar machine oil. Clean the motor shaft with alcohol as well as the brush drive area, and the inside of the drive belt. Test on a carpet for improvement--if still stopping, replace the rubber drive belt. Hope this helps!
Nov 21, 2010 | Bissell 3920 Bagless Upright Vacuum
Sweeper wont pick anything up. When the motor runs it sounds like the belt is broke, but it is not. It revs real high. There are no clogs and the filters are clean. I have no idea what it is, and I...
to me it sounds like a blockage?having worked on these machines for so long,when the motor runs high as you say then its under pressure im not convinced you have cleared the blockage take another look ,i use a old wire coathanger straightened out to push the rubbish out,if that fails,go out and buy yourself a new machine you derseve it and you will be surprised at what the new machine can do..adrian,,,,
Sep 06, 2010 | Fantom Vacums FM741 Twister Bagless...
I have to push the sweeper, there is no drive
Be sure your belt isn't slipping on the beater bar. Might be time to get a new belt or at least take off the beater bar and clean everything. Dust can cause it to slip
Jul 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have fantom FM741H It sadenly stop working. I checked plugs,circuitbraker. They are Ok. What is possible problem? Thanks
I have the same sweeper as you. I have had this sweeper over 10 years. I purchased it from HSN. Model fm741h. Ok here we go. I paid 299. for it 10 years ago. It worked perfectly. Picked up all sorts of things. It stopped working about 5 years ago. I kept it hoping I could get someone to go over it with a fine tooth comb in my area. No one worked on them. So I still kept it. Just today 09/4/2010 I was looking at it. I decided to start taking the whole unit apart. I come to find out all the filters are clogged. I have never replaced them or the belt. The belt was fine, the motor runs, but its just not picking up anything. So inside the canister was caked with dirt. I mean literally DIRT. Inside the part that spins is another filter. I checked the prices on those. Anywhere between 23.00 up to 50.00. So I took a toothbrush and ran it under hot water. Scaped off all the dirt, let it dry and presto....I have my TWISTER back. YIPPY!!! I can't see spending that much on a filter when all you have to do is scrape the dirt off of it. Works perfectly. Now that I know what to do....I'm a happy camper.
May 10, 2010 | Fantom Vacums FM741 Twister Bagless...
How to change belt on Dirt Devil Model 2003 can vac sweeper
I found out that the Royal Mfg. Co. used the same schematic from this model to make newer models which had a belt, however, this older model that I have does not have a belt drive.
Jun 14, 2009 | Vacuums
Roller brush doesn't turn
Sounds like the belt is maybe slipping did it brake the new belt as well?
Mar 10, 2009 | Vacuums
Sweeper belt
Greetings from,
Have you replaced the belt with a new one yet? You may want to try replacing the belt, as with flat belts like the Fantom Thunder, they do stretch out 4 -5 inches after time. We in fact recommended replacing a flat belt every year, even if the belt doesn't break, because of the stretching. I think what may have happened, is that your belt is stretched to the point where it will not stay on the pulley as soon as there is any tension (putting the brushes on carpeting), which will cause the belt just to slip off.
You should be able to replace the belt (very inexpensive, we sell Fantom belt for $2) and this should take care of the problem. When you replace the belt, you should also take the roller brush apart and remove any hair, or thread that may be wrapped around the bearings. You should be able to remove the bearing cap by pulling them, or holding one end, and unscrewing the other.
I'd even be willing to send you a free Fantom Thunder belt, if you'd be so kind to vote Fixya for this answer :-) Just send me an email with your name, address, and the exact model number (located on the back of the machine, or the bottom of it) of your vacuum, and vote Fixya, I'll immediately ship you the belt for free!
Please let me know if you have any other questions I can help you with.
Chris Jones
Oct 13, 2008 | Fantom Vacums XT450K Upright Vacuum
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
