To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
yes you need a email connect thro modem or router eternet port or use a wireless adapter and find your signal in system settings ok now click on join live and it will walk you thro the easy steps to join
Make a new user profile and try to create and x-box live profile that way, ours got wiped once and we got the same message and that is what we had to do.
1) Go to xbox.com and make a gamertag from the website.
2)Go buy a xbox live subscription for best buy, wal-mart, and other electronic store.
3)Get a 360 first of all lol
4)If you are going wireless, go buy a wireless adapter for 75$-100$
5)If you are going wired, you will need a ethernet cable
6)connect your 360 with whatever method your are using (wired or wireless)
7) Turn on your 360, test the connection
8)When u done with that, go to "Join XBox Live" on panel of the 360 guide
From there it should be unexplainable because its pretty easy. I hope i gave you enough infomation. Good luck
Step 1
Form your Xbox 360 you need to be connected to the Internet by a straight LAN line or wirelessly. You can test you connection by going to the setting screen on your Xbox 360.
Step 2
Once connected to the Internet for your Xbox 360 go to your main account screen and find the tab that says "Join Xbox LIVE" click on that link then follow the simple instructions that the Xbox LIVE will provide. At this point you should have a name in mind for your gamer tag.
Step 3
Xbox 360 LIVE has several different options available for memberships. They are a monthly, 3-month and 12-month membership accounts. I would recommend a simple one month account if you just wanted to check out the features offered on XBOX 360 LIVE. If your an avid gamer and love to play games online with friends, the 12-month Gold membership is the way to go.
Step 4
Once you've completed the process of joining Xbox 360 LIVE, they will send you a confirmation email confirming your membership. Now you can log on to Xbox 360 LIVE and start doing this like customizing your avatar and playing online multi-player games.
First off (may sound silly) Make sure you have your Xbox connected upto your Modem via USB or Ethernet, make sure your Xbox is connected to the net by going to the dashboard then select JOIN XBOX LIVE then follow the on-screen instructions
You need to sign up through your xbox or by calling 1-800-4-My-Xbox. You need your xbox to be connected to the internet either by plugging in the network jack in the back of the console, or buying a wireless network adapter and hooking it up to your local wireless network.
If you think its the wireless adapter, try using a laptop (that has wireless) to connect your xbox to your network. Just get a straight through (network) cable connect one end to the xbox and the other into the ethernet port on your laptop. Then go into your network settings and bridge the connections (if you don't know how to bridge connections try youtube or just google it) Now your laptop acts like your wireless network adapter. See if your problem occurs with the laptop, if not then it is the adapter. I hope this helped solve your problem.
ok, so if you want to do it wirelessly you need to get the wireless network adapter for the 360. i got mine at target for about 100 bucks. You also will need a Xbox live Gold card if you are wanting to play with your friends. you can also get your subcription over the xbox by using a credit card. The setup is pretty simple, just follow the on screan instructions. I am assuming your dashboard uses the "blades". if so, go over to the marketplace section, and go to join xbox live. then it will guide you through the process.
