Question about Garden
I have a mtd riding mower and it cranked up but would cut off within 30 sec. I kept starting it over and over until it finally stopped starting. Is it the battery?
    President:
  • 1,033 Answers
Biggest concern now is, after starting it over and over, you may have burned up the starter. But the first problem most likely bad gas, drain all the gas out and loosen the fuel bowl then refill with good gas. Your battery may be drained by now from starting it so many times.
Posted on May 10, 2010
MTD 638 lawn tractor does not spark on starting. Cranks but does not start. Changed ignition coil and spark plug still does not have ignition
Something must be stopping ignition do u have a oil level sensor on the engine sometimes the sensor goes bad or low oil in block cuts off ignition..
Nov 07, 2016 | Mtd Garden
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
How do you find an inline fuse for a mtd riding mower 38 inch cut 14 horsepower
Start at the ignition switch and look for the starter wire..it should be the one tat is slightly heavier and normally red..and goes to the solenoid pos side..good lu k
Nov 16, 2014 | Mtd Garden
My riding mower stops moving forward after 30 minutes of cutting it starts right up the blades engage properly and cuts great it will just stop moving
Check under the seat under the battery box there you should find the drive pulleys for the rear end the belt could be worn out and turned inside out causing it to slip or stop pulling once it heats up mine was installed inside out from Lowes when I purchased the mower causing me to replace the belt hope this helps
Sep 16, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Mtd 13AI607H118 Mower starts,when it warms up it stops, I wait and it starts and shuts down again/
Possible I/C cutting out when it warms up therefore it stop producing spark so swap out with a known good one
Jun 14, 2014 | Mtd 46" Dozer Blade, Fits All & Yard -...
Yardman seris 155 42 inch cut will only run for 30 sec to 1 min then stops why
try and run it with the fuel cap loose the vent in the cap could be plugged
Jun 04, 2012 | Garden
Have new battery, mower crank a few seconds then just start clicking. but the lights are bright, the mower is a older model HUSKEE 24 HP 54in cut
The starter solenoid is most likely faulty and not carrying enough amperage to the starter motor. Regards Phil
Apr 12, 2011 | Mtd Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
