Information is not clear; however, if you mean to clear contents (photos, movies) from the internal memory, try the following.
1. Switch off, remove the SD card, re-start the camera.
2. Switch to playback mode; there you will find the photos/ videos stored in the internal memory. Manipulation of those media is normal.
Please see below instruction on how to delete internal memory on your camera:
You needs\ to make sure that all the pictures that you want to keep either
on the card or internal memory are copied on to your computer.
Next with
the card in the camera you should be able to look at a picture and hit
delete. When you do this it should give you an option to delete a
picture or delete all. Deleting all will clear the card.
Next it should
give you the option to look at and clear the internal memory and delete
it and your done,
Note: you must removed the memory card before deleting the internal memory
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks Regards
what you need to do is to clear up the internal memory or if you have a memory chis or card then move all of your internal memory into that then clear the entire phone, also you can try to clear the caches or cookies in the web browsers memory.
Put memory card in camera, go to menu and select Copy option to copy internal memory picture files in to memory card.
take out memory card from camera and again go to menu, select format in memory options to format internal memory, that way all files in internal memory will be deleted at once and you have back up files on memory card.
Hi there internal memory means inbuilt memory. When you click the snap all photos are save in your camera internal memory. I hope you use external memory card. Go in settings and select the memory card( external) for further snaps. Then the message did not come again until full the memory card. And if you want to clear the internal memory card then connect your camera with your PC then copy the all photos from the camera & paste in computer. After that go inside the internal memory of camera via computer & delete them. Then your camera in build memory card will empty. I hope you understand . If you have any question then ask me. Thanks & waiting for your feedback.
Take out memory card from camera, format internal memory to delete all pictures at once or delete them one by one. Once memory card is inserted in camera, internal memory is no longer available to store/ delete pictures so remove memory card from camera to get access to internal memory.
Turn On camera -Press Menu, scroll down look for setup then press Ok button.
-Under setup menu scroll down again and look for format then press Ok Button -Under format highlight or choose Internal Memory then press Ok button -It will format or clear the internal memory
