Question about Troy Bilt 5.5hp Self Propelled Mower
Self propelled mower will start but want stay running long? it runs about 3 or 4 min. then stop and when i restart it, it will start back up.
    President:
  • 1,033 Answers
The fuel bowl has a float and needle, if the float isn't floating to open the needle for gas to flow into the carb, it will cut off. A kit can be purchased for about $5 or take yours out and soak and clean then replace. Usually when these go bad its best to replace them.
Posted on May 10, 2010
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Troy-bilt self-propelled w/briggs and stratton 6.75hp after starting runs for 3 or 4 mins. dies out and in 3 mins later will start and do the same thing any suggestions?....thanka abb
Hello. Your carburator is partially clogged up. That said, if you havn't installed a new fuel filter and new air filter this year do so. Also put in a new plug if u havn't lately. Finally get a bottle of a fuel additive called seafoam and pour it into the fuel following the directions on the bottle. J.
Aug 16, 2010 | Troy Bilt 5.5hp Self Propelled Mower
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
I have murray self propelled lawn mower. Last
Remove the air breather filter, it might be dirty. Stephen.
Sep 21, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
373 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
