Question about Dualit Vario 3 Slices Toaster
Eliment top eliment wont work on toaster oven
  • 37 Answers
Service center:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Nov 20, 2008
    Problem Solver:
  • 9 Answers
Did the top element ever work? Perhaps it only works in "broil" setting.
hamar nnelg
Posted on Apr 01, 2008
Remains cold when turned on. Is not working
sometimes the heating eliment opens or corrosion steps in and cause the problem. If technically minded you can unscrew the unit and check these parts, otherwise it will be wise to take it to an appliance technician.
Nov 10, 2010 | Euro-Pro EuroPro 6Slice Toaster Oven with...
Double oven,the top ovens lower heating eliment will not work-I have relaced it and tried the lower ovens eliment still nothing,the broiler(upper)eliment works fine?
There are some small relays on the circuit board in the area of the controls. These relays are undersized and normally fail shortly after the warranty period. If you are handy with electical work and a soldering iron you can replace the components on the board using standard items from Radio Shack. If not, then buy the circuit board but expect to pay a lot. I once fixed a friend's oven and broiler by putting a low voltage optical semiconductor relay from Radio Shack into the space of each failed mechanical relay. Then I used those to operate large 40A definite purpose contactors -- normally used in HVAC systems. This required addition of a 24vac power transformer. All of it fit easily into the space behind the control panel of her drop-in range. The beauty of the optical semiconductor relays is that they isolated the electrical system of the original circuit board from the additional parts I was supplying. This makes is easy for anyone who works on it later to see the nature of the upgrade/repair.
Dec 12, 2009 | Ovens
The heat element doesn't go on
FInd the break in the heater eliment and twish it bac together. It will then work again for a while.
Jun 29, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
The egg eliment doesn't work.
There is both a relay and a thermal fuse on the egg heater circuit. Could be either of them.
Jan 12, 2009 | Back to Basics TEM-500 Egg & Muffin...
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Lower heating eliments don't heat or glow. Only top ones work
The elements are not orderable, but you can call Cuisinart with your serial number - the product has a 3-year warranty, and that is definitely a defect - will they glow if you put them on Toaster setting?
-Tha Mp3 Doctor
Aug 03, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Dualit Vario 3 Slices Toaster Logo
101 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
