Question about HP Photosmart C7280 Laser Printer
When copying comes out black - HP Photosmart C7280 Laser Printer
Xerox 3050 service manual
sir,
i want get solution for my 3050 xerox machine. while taking the copy the background coming black, idon't know the reason, i changed explosure lamp, primary corona end block, tonner, but till the problem is background black, if one copy comes clear another copy will be black. if know the solution kindly pass the message to my cell no.7760191629.
thankyou,
regards,
prabhu
Sep 11, 2010 | Xerox Office Equipment & Supplies
Out going fax is coming black
FIRST test copying. if the copy come out completely black, then the exposure or scanner lamp or contact image sensor is dead,not lighting on. Now if the copy has black only black lines on it,then you can clean the place where the document passes thru where the light of the exposure lamp projects unto the text of the document being scan,which is the small glass on the left side of the platen glass when you open the auto document feeder.NOTE: Lay your document on top of the platen glass & make copy if the copy come out clean as you needed it,then the lamp is O.K. Then the small glass just need to be clean. If the copy is completely "BLACK", then the lamp is dead, or the circuit that control it. In thus case then you need a technician to do it
Jul 14, 2009 | Panasonic KX-MB781 All-In-One Laser...
Machine over heated now the copies are black
Do the copies come out totally black or just dark???? Does the copiers scanning lamp turn "ON" when you go to make a copy? If you smell something burning, you may have paper wrapped around the upper fixing roller...
Apr 28, 2009 | Sharp AL 800 Copier
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
All the copies are coming out solid black
Dear sir ; Check the exposure lamp or thermo fuse for exposure lamp. Stii have problem ? let me know.
Jan 14, 2009 | Copystar Royal - COPIER STAND Copier
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Xe80 copies coming out almost black on auto or light
Hello sir; Just replace drum cartridge it will take care your problem, GOOD LUCK!
Oct 30, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
BLACK COPY PROBLEM
- Try to check all Lamps
Sep 22, 2008 | Toshiba e-Studio163 Copier
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
HP Photosmart C7280 Laser Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
