Question about Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V
Pump will not turn on after being outside all winter(water was drained from pump housing. Just a humming noise. Thanks!
  • 198 Answers
Possibly the shaft is stuck. with the power off, try accessing the shaft from the inside the basket--maybe it can be reached with a screwdriver---try to turn the impeller a few times to make sure it is turning freely.
Posted on May 11, 2010
I have a fisher and paykel top loader 10 kg but not spinning and make that humming noise when it's on spin cycle, water drains slowly.....please help
sounds like theirs a large blockage in the drain pump housing, the drain pump is just twist locked onto the bottom so you just lift the little white lock clip then twist the pump and it will come off and you will be able to see inside the housing and clear the blockage
Jan 28, 2017 | Fisher and Paykel Washing Machines
How to winterize
ok, been a while so lets ee if I can get this all down.
1 - Drain water from your holding tank and remove drain plug in hot water heater. Drain holding tanks ( Waste )
2- turn on bypass for hot water heater ( instruction if needed )
3 - Get yourself some winterizing fluid ( can't remember exact name ) from your local Dealer . 2 or 3 gallons should be good
4- Poor this fluid into your water rez tank. All of it
5 - now go around to EVERY tap in your trailer ( one at a time ) and turn on cold water until water runs pink ( or what ever colour fluid you bought ) Close faucet them do the same for hot water tap. Repeat this at every faucet. Even the ones outside if you have any.
6 Don't forget to flush toilet in water runs pink.
7. Ensure all gas vales have been turned off ( tank vales included )
If you did everything right you should be good to go.
Plz double this list to make sure I covered everything
Oct 02, 2016 | Keystone 2015 Alpine 3555RL
How do you de-winterize 28DSBH
Connect the trailer to the city water supply, turn on the water and open each faucet until clean clear water is present. Don't forget the toilet and outside shower if equipped. Next reinstall the anode rod (suburban) or drain plug (atwood) into the water heater. Go to the back side of the water heater and close the valve on the pipe that connects the cold (bottom line into water heater) and hot (upper line out of the water heater) and then open the bottom cold water line valve and, if equipped, the upper hot water valve. This will fill the water heater. Open the hot water valve at the kitchen faucet. When the water flow is steady the water heater is full and ready for use. If the unit is equipped with a water filer, after all is flushed out, turn the water off and remove the filter housing. Install a new filter and re-secure the housing and turn the water back on. If you are using the fresh water pump, it is possible that the winterizing valve for the pump was left open. If so, close that valve which will divert the pump back to drawing from the tank.
May 08, 2014 | Jayco 2013 White Hawk Ultra Lite 28DSBH
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
I have an U-Line model # WCM48A that has a water reservoir/pump. I removed the reservoir/pump and directly connected to the home water supply. Previously the icemaker worked fine but now neither the...
the condensate drain pump will shut unit down and only run drain pump if over fill is seen may be noise you are hearing
if condensate pump removed has to be wired so kill switch in drain pump is over ridden for gravity drain
Nov 02, 2017 | U-Line Refrigerator Ice Maker
Water will not drain. humming noise
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Humming noise is due to loose connections on drain pump or due to faulty drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Nov 20, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Turns on makes weird humming noise
The noise is most likely your drain pump trying to clear water from the sump area. If you remove the bottom screws holding the lower access panel in place, look for the drain pump and a block rubber hose connected to it. I suspect there is something preventing the pump from draining all the water. Remove the clamp holding the hose to the pump (have towels handy as there will be water) and clean out the sump, then put it back together and give the washer another try.
Mar 08, 2009 | Frigidaire GLTF2940ES Front Load Washer
Humming noise
humming is the motor powered up but not turning. burning smell is the motor overheating. cause may be the motor capacitor which is a cheap part. try replecing it and hope thge motor survived. could also be a foreign object in the pump impellor
Mar 13, 2007 | Zanussi 24 in. DE6744 Free-Standing...
Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED 2 HP 115/230V Logo
274 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
