Question about Canon BubbleJet i560 InkJet Printer
Flashing orange light 5 times followed by green
Will not print. I get this message
"Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on."
The status light flashes orange 5 times followed by 1 green. Repeats
Any suggestions?
    New Friend:
I am also having this problem, would love someone to give us a solution before I through it out the window.....
Posted on May 30, 2010
    New Friend:
Having the same problem! Can anyone help???
Posted on May 11, 2010
2 Suggested Answers
SOURCE:
SOURCE: Canon i9900 Error reads as follows. Operator
there is something inside the printer, i have the same problem and that was it, a paper or something blocking the headprint to run from right to left
Posted on May 28, 2009
Canon printer i865 Orange light blinks 5 times and the following message appears: "Operator error. Press printer's RESUME button. If this doesn't clear the error, cancel printing and turn the...
Dear Bruce,
Blinking in orange 5 times indicates that the print head of your printer is faulty. To ensure this you can compare by using another print head. But first,please remove the print head and check whether it is burnt. Some short circuitry may cause the problem. Thanks.
Source:
Printer Clinic
Dec 26, 2010 | Canon Office Equipment & Supplies
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i860 printer not working
The error code says that your printhead is bad and needs to be replaced. QY6-0049-000 around $40.00
Jun 30, 2009 | Office Equipment & Supplies
Canon i9900 Error reads as follows. Operator error. Press printer’s RESUME button. If this doesn’t clear the error, cancel printing and turn the printer off and then back on. I've cycled through...
Oct 22, 2008 | Office Equipment & Supplies
5 amber flashes
Operator error.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Canon BubbleJet i560 InkJet Printer Logo
1,382 people viewed this question
Clive
Clive
old marine
old marine
