Question about Onkyo TX-SR705 Receiver
Sound only, no picture, when Blu Ray hooked up to receiver through HDMI. Input was assigned correctly.
    Problem Solver:
  • 11 Answers
Are you sure you have the HDMI output turned on through the DVD player? are you sure you have the following;
HDMI Monitor out running to the TV
Correct input on the TV
Posted on May 11, 2010
Yamaha purple screen rx-v373
I had this same issue. I think I finally resolved the issue by turning off HDMI Control (HDMI-CEC) on my Blu-Ray player. I had the Blu-Ray player plugged into a Yamaha RX-V375 (almost an identical receiver). I think the source of the issue was that my TV does not not support HDMI-CEC. Turning off HDMI-CEC on the Blu-Ray player fixed the issue. The Yamaha receiver already had HDMI Control disabled, and all the other HDMI devices appeared to have HDMI-CEC disabled or not supported.
In my case, the symptoms of the issue were that I would see the correct picture for a second on power up, then the picture would go away. For the Blu-Ray HDMI input selected on the receiver, I would see a solid purple screen and a blank screen for the rest of the inputs. Sometimes switching inputs fixed the issue, sometimes power cycling would fix it, but it was getting very annoying.
Dec 03, 2012 | Yamaha Audio Players & Recorders
Unable to connect a blu ray dvd player to onkyo tx-sr605 via hdmi
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Apr 13, 2011 | Onkyo TX-SR605 Home Theater Receiver 7.1...
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | Electronics - Others
Connecting Sony BDP S550 Blu-ray player to my Denon 3802 receiver.
The only thing you need is an optical audio cable (toslink) connecting the Blu-ray blayer with one of the three inputs on the AVR3802. Then assign this input in the system menu to the input you like (e. g. DVD) and that should be it. The Receiver automatically detects the sound format from the Blu-ray and changes from stereo to DTS, DD5.1, 7.1 or whatever.
Regards
Thomas
Nov 01, 2008 | Denon AVR-3802 Receiver
Home theater set up
I want to download instructions to record tv shows while I am gone for a day or two,on my sony model#kdl-46xbr2. e-mail bmllrctg@yahoo.com
Dec 27, 2007 | Televison & Video
Onkyo TX-SR705 Receiver Logo
158 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
