Question about Garden
Have deck off and new blades on my MTD Yard machine 42 in . Is there a easier way than removing all the bolts in the pulleys and on the gurads... just wondering ! Thanks, Bob
    President:
  • 1,033 Answers
If replacing just the blades, it's easier to turn the mower up, lock the blade down with a piece of wood or ?? to prevent moving while taking bolt off. It takes about 3min to change them this way.
Posted on May 10, 2010
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
Cutting blade barring ***
I think that part is called a mandrel, pulley on top and blade on the bottom.
Generally you remove the deck, take off the deck belt, take off the covers, take off the blade, remove the bolts holding the mandrel to the deck. Get a new mandrel at a sears store or small engine repair shop and reassemble in reverse order. May want to do them all while you are at it and save yourself duplication of work next year.
Jun 04, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I need to remove a bent blade on a yard machines 42 inch deck.
To remove the blades from a tiller, all you need to do is pull the pins out of the blades at the shaft and remove the offending blade. If it is an inner blade, it too will have a pin. The pins have a head on one end, pass through the shaft, and a locking pin through the other end.
Regards, --W/D--
Jul 20, 2009 | Mtd Products Yard Machines 158CC Tiller
How do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Jul 08, 2009 | Mtd Products Yard Machines 158CC Tiller
Drive belt diagram for mtd rideon
hi;go to partstree.com.put in your model # and make.then click on deck assembly.it will be what your looking for.hope this helps.please rate this;Thank's
Jul 04, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Craftsman mandrel replacement::?????HELP
You dont have to drop the deck. Remove the belt first then hold the blade in place so you can loosen the nut on top of the pulley. after you remove the pully then remove the blade. There are 3 bolts holding the mandrel in place remove the bolts. Then pull the mandrel out from underneath the mower deck. There is a shroud that will come loose with it or it may stick from accumilated grass regardless it needs to go back during reassembly. When putting it back together the 3 bolts are usually self tapping into the new aluminum mandrel. Its much easier to put these in and take them out before you install the new mandrel as the bolts cut the threads.
Hope this helps
Brent
Jun 23, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
