Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
SOURCE: Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Posted on Feb 17, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
SOURCE: Haier washing machine error 1 message does 1 mean
You need to close the machine door, thats what error 1 means :)
Posted on Aug 01, 2010
SOURCE: my whirlpool cabrio washing machine keeps flashing F1?
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies,
and visually check that the P11 connector is inserted all the way into
the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has
failed: Unplug washer or disconnect power. Replace the machine/motor
control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
and visually check that the P5 connector is inserted all the way into
the machine/motor control. If visual check passes, replace the user
interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or
disconnect power. Replace the machine/motor control assembly. Plug in
Some buttons do not light indicators:
and visually check that the console electronics and housing assembly is
properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Posted on Sep 20, 2010
Mar 09, 2018 | Washing Machines
Mar 07, 2016 | Washing Machines
Nov 16, 2015 | Whirlpool WTW6400SW Cabrio Washer
May 01, 2012 | Washing Machines
Nov 28, 2010 | Haier Washing Machines
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Nov 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Apr 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Feb 13, 2009 | Whirlpool Washing Machines
Dec 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
301 people viewed this question
