Question about Dryers
It is noisy, the 2 wheels were changed out, and loud squealing noise continues. What do I do about it?
  • Dryers Master
  • 8,220 Answers
What about the idler? You know I use a safe non flammable oil that is temp resistant. Zoomspout oil. $2 any ace hardware. HVAC approve zoomoil is a good lubricant for dryers. OIl everything that turns.
Posted on May 10, 2010
2008 Mitsubishi lancer radio from loud squealing noise
What is causing that irritating noise? ' DSMtuners
www.dsmtuners.com > ... > Articles: Miscellaneous
Jun 1, 2009 - 2 posts - ‎1 author Check the ECU power relay in the console, under the radio. ... You hear a loud clicking type noise from under the hood when you try to start the car. .... You hear a squealing, grinding, or rubbing noise in the lower timing belt .... The Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, Mitsubishi Galant VR-4, ... LOUD squeak when turning steering wheel (Video Inside)
Mar 5, 2011
Why does my alternator belt squeal so much on initial ...
May 14, 2010
More results from www.dsmtuners.com
Lancer Troubleshooting [Archive] - evolutionm.net
www.evolutionm.net/forums/mitsubishi-evolution-forums/f-203.html
NEED RADIO HELP! ... Help not start Lancer GT 2012 EngineOverheating STOP SAFELY warning on ... AC ISSUES 2011 Mitsubishi Lancer ES · 2008 Lancer GTS no start please ... 2011 lancer no sound · Driver/Passenger side floor squeaky? ... plastic piece of rear shelf rattles a lot · Very loud noise on Lancer ES 2008 ...
Dec 03, 2015 | 2008 Mitsubishi Lancer GTS CVT Sedan
Squealing noise while driving
Did you check the rest of the U-joints. If you have a hanger bearing, you should have a 2 piece drive shaft and thus 3 more U-joints that could be bad.
Aug 04, 2013 | 2000 Chevrolet Silverado 1500
The brakes were changed, the rotor taken to the machine shop and now there is a constant, noisy and loud sound every time the car is turned on. It only stops when the ignition is turned off. What is...
If the noise is only present when the car is turned on but not moving it is probably coming from the engine somewhere. It could be just the belt squealing or the bearings inside one of the pulleys that the belt is running on. Can you describe the noise? Is it like a loud squeal or a chirp? Is it a growly type of noise. Is it like a loud put put put which could be an exhaust leak? What I'm getting at is if the vehicle isn't moving and the noise is present then it won't be the brakes or a noisy u-joint or the suspension. Open the hood up and listen to where the noise is coming from, this will help pin point the problem. Let me know, please ask questions we're here to help.
Jan 16, 2011 | Ford Escape Cars & Trucks
When the dryer tumbles, it makes a loud noise. What could it be? How do I fix it?
Go to Sears and purchase a new belt & idler pulley wheel for yours. The bearing in the pulley has dried up bearing causing this noise. The belt will be stretched and replacing it the same time will save a future headache
Dec 27, 2010 | Dryers
Noise at pump
Your problem is just a little vague. Noise could be several things including.... vibration can cause noise especially if the pump is not sitting solid on the ground. Cavitation around the impeller can cause the pump to be noisy. something stuck in the impeller can not only cause a number of irregular noises, but also affect performance. If the bearings are going bad they can make a number of bad sounds; anything from just sounding a little noisier than normal or a loud grumble to a loud high pitched squeal the can make a banshee turn and run.
Sep 18, 2010 | Jandy PHP High Head Pump 2 HP Up rated
2000 Mitsubishi Galant 4 cyl ES underhood squeal on right side
The probable causes are: 1. The drive belts are slipping. 2. The drive pulleys for some engine accessories are misaligned. 3. You have turned the steering wheel to the limits. 4. The drive belts are loose.5. Your brake drum backing plates are rubbing against the brake drum. The brakes also might be a problem. check the brake drums/discs. Finally check your wheel and wheel alignment.
May 08, 2010 | 2000 Mitsubishi Galant
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Loud Noise From Dryer
*Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
*Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
*Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
*Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
*Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Sep 03, 2009 | Maytag Dryers
My Maytag dryer makes an aweful noise.
Typical parts that wear out and get noisy on that model are the two drum rollers (part # 12001541), the front drum glides #306508, the idler pulley Y303705 and the blower wheel 303836. None of these parts are very expensive, but to do all of them would definitely add up to the point that you might want to think about whether or not you want to keep the machine in operation especially after 10 years of good service.
Jan 04, 2008 | Dryers
Dryers Logo
Top Dryers Experts
