Question about Car Audio & Video
Panasonic cx-dp601 cd changer
Can one fit the above into a mercedes c class with a drop cable and could you please tell me where to find appropriate cable or give me a pin out for the 13pin din socket
  • brigs Mar 28, 2008
    can one fit a panasonic cx-dp601en into a mercedes with comand radio with a drop cable if possible where can i obtain cable or could someone give me the pin out for the 13pin din socket
I need a wiring diagram on how to configure a new harness for my panasonic DP 801 8 DISC CD CHANGER....MODEL CX-DP 801 EN
All parts and service manuals can be obtained by calling the Panasonic National Parts Center directly at 1-800-332-5368 9am-8pm EST during weekdays.
Aug 04, 2013 | Panasonic CX-DP801 8-Disc CD Changer
E-1, e-2
My Panasonic CX-DP801 8-Disc CD Changer does`t played 0000 on display
Sep 25, 2012 | Panasonic CX-DP801 8-Disc CD Changer
I need the wiring diagram for my Panasonic DP601
If you mean the CX-DP601 then you'll find the wiring diagram on page 16 of the manual.
Jun 06, 2012 | Car Audio & Video
I WANT CHANGER MY PANASONIC CD CHANGER WITHOUGHT REWIRING .
I would like to advise that it would be better for you to update to a universal type adapter that can be easily fitted to your Player. This adapter would be able to play from memory sticks, usb memory or even your Ipod and that means all your MP3 can be easily stored and carried over. The DVD changer is compatible. However I hope you will decide with my advice and check for the models available in your city. So go with the times. Good day
Aug 02, 2010 | Panasonic CX-DP801 8-Disc CD Changer
I removed my Mercedes 6 disc cd changer from my
Without power. you may just have to disassemble the unit.
Mar 08, 2010 | Panasonic CX-DP88 8-Disc CD Changer
I got problem with my sat nav on s320 cdi (2002)
Hi, You need to replace the cd changer. This is very common on these vehicles. The best place to get the changer is the dealership. I have seen them fit aftermarket changers in there but can not give any advise on that.
Mar 23, 2009 | 2002 Mercedes-Benz S-Class
Panasonic CD Changer with Pioneer reciever
Panasonic CD changers have a specific plug in that will not work with the Pioneer head unit. The Pioneer uses the IP-BUS plug. You will also not be able to convert the unit to work because the data between the two cannot be controlled and you won't have the ability to use the units together.
Sep 12, 2008 | Panasonic CX-DP801 8-Disc CD Changer
Panasonic CX-DP880 connector pins
what specific connector output/input pins..?
Aug 10, 2008 | Panasonic CX-DP880 8-Disc CD Changer
Car Audio & Video Logo
318 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
